Want to make sure your drivers are in place and no errors have occurred? if you dont have a motherboard disk or a disk with the drivers you will need to download them IE: motherboard name vga driver you might have to try a few times to get it right
Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small + you should see the model of your PCI Express graphic card there.
If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly.
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
you might uninstall the display adapter restart your computer then reinstall the display adapter and its drivers
If you computer came with a motherboard disk the drivers could be on it
If you dont have the motherboard disk you might need to download them
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
The computer manufacturer makes the device versatile. Usually the feature functions displayed on the computer at acquisition is the minimal of the device achieves updates to suit with customer experiences. The computer devices have several hardware and software expansion capabilities. For example, prior programs in the computer are compromised to attain manufacturer default front. Once the computer was restored is likely not to preserve the user modifications also required to update modify every resources either as separate entities also known as peripherals. Allow the computer to search to acquire and modify missing resources by activating the system updates or upgrade features. Connect the VGA cables on the computer to make possible initiating the process of modifications to retain the formats. The computer may require manual installations of programs either in codes or disk version depending on the capability to perform compile update solely without expert manipulations. Refer to the computer device user guide to attain capability requirement to revive VGA capabilities. The owner user guide makes available details resources either as customer experts supports or diagnostic processes to make restore soon after remodifications.
