Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Or you can buy an external battericharger like the BC-65. It's not cheap either but you only need one item. Instead of the USB cable you can use an external USB card reader that can take XD cards.
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Try this site for a firmware update. You need to get a AC power adapter for it to work though. It is from Fuji and it worked fine for my A120. The older XD cards are of a different format then the newer ones so if your new XD card has an 'M' on it you will need to do the firmware solution.
Good luck http://www.fujifilm.ca/x3719.xml
first thing i would do would be to make sure you plug the cable first into the usb port with the camera off then turn on the camera, see if it is recognized by the computer. If not the next step is to check your usb driver to make sure it is working. Try some other usb device. If it is recognized then i would make sure you have seated the memory card properly in the camera as well as the cable. I know that sounds dumb but that little usb cable to the camera has to be well seated. You may have to update your driver for the usb port.
This is a CCD sensor ( see pic below from Canon camera with same pixalage and specs ) problem : outputting too much noise or nothing at all so the sensor must be replaced ( not a big job but ha sto be done by someone with experience and the right parts ). Fuji will repair free of charge , if I am not mistaken, so you need to contact your Fuji agent .
