When i switch on my phone it shows contact service and its off
• Connect your phone to a charger
and let it charge until the battery is full. Leave the phone plugged in
throughout the procedure. Unlock the phone by pressing "*" then "unlock. Type in the code "*#7370#" then enter your security code. The
default security code for Nokias is "12345." Wait 2-to-3 minutes for the format to complete, then your phone will
switch itself back on.
SOURCE: nokia 3315 contact service error
i am the service and i am teling u that the phone shud ve a new firmware
get it to a repairshop and tell them i want to flash my phone they knw what to do after that sentece
SOURCE: NOKIA2626 CONTACT SERVICE PROBLEM
your phone's CPU had a problem, you need to reformat the phone to fix the problem. go to your nearest phone technician.
SOURCE: nokia phone 3120 showing contact service
NOKIA 3120 contact service display on lcd after switch on
SOURCE: how to full format nokia 5130c-2 mobile
Have you tried the key combination method? if not try it.. Press * - 3 - Green button and power button simultaneously, I mean you have to press all the buttons while the phone is switched off. It'll boot up and you'll be presented with a menu to provide your input. Good luck...
SOURCE: my nokia 5130 xpress music shows contact service
my nokia 5130 xpress music is showing contact service plz solve me
Possible that this can be a hardware or a software issue , Assuming that the phone has hung up because there are errors in the software we can try a reset. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone.If the Sim does not register clean the contacts on the board.Also counter check the SIM on another phone. If the phone does detect then it is confirmed that there are faults in the hardware. Seeking help from the authorized service /support center is most ideal. Take estimate and decide.
whenever i try to on the phone the nokia logo comes and a error message come contact service and phone goes off
