Every time i turn it on it leaks water all over the floor
SOURCE: I have an everstar mpk-10cr and it leaks water out
This cap must be in place in all coolers I have seen. Frequently there is a gasket that is identical to the type used on a common garden hose. It needs to be clean and free of cracks. They only cost pennies. I don't understand what you mean by "I plugged it up but water did not go into the normal receptacle."
I will assume you mean that this is a manually filled unit and not attached to a water source. If that is the case give me more details on what you mean.
SOURCE: My Everstar MPK-10CR portable 10,000 BTU's is blinkink P1 all tim
Make sure the level arm is also making good contct with the water bucket when you insert it. You can awlas pull the level towards you to adjust for better contact.
SOURCE: just got a used everstar
Yes there is supposed to be a screw in plug. You can probably order one directly from Danby
800-496-6049 Make sure you have the correct model numbre when you call.
Hope this helped you. Please let me know. Thanks.
