Closed Caption function to that channel you select is ON. Make it OFF, when you are in that channel which displays this black box. It will be best to reset the TV to its factory settings first, and then re-tune it. for more details, refer its user manual.
your closed caption system is turned onn to its TEXT FUNCTION use your remote to find the CC or closed caption option and turn it off and the block will go away . good luck
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
