Philips FWC1 CD Shelf System Logo
michele corson Posted on Feb 27, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Philips magnavox fw-c1 3cd, 2 cassette, am/fm stereo
I have tried numerous things to turn off my stereo's demo. i turn it off and 5 seconds later the lights flash and words flow across the screen. i lost my manual. please help me to turn that off. thanks
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Apr 08, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2174031
Points
14133
To stop the demonstration mode
• Press and hold stop (on the system
only)
for five seconds when the
system is in demonstration mode.
ª The demonstration will stop.
ª "DEMO OFF" is displayed.
ª The system will switch to standby
mode.
  • Jonathan Harris Jan 30, 2014
    Thanks - I'd been trying different button combinations for ages until I found this; worked fine.
Hook up for Philips FWC5503701 Stereo model.
Question edited for clarity and spelling of the maker.
Question moved from Misc.
Philips FW-C550 Operating Instructions Manual
ManualsLib https://www.manualslib.com > ... > FW-C550
View and Download Philips FW-C550 operating instructions manual online. FW-C550 stereo system pdf manual download. Also for: Fw-c500.
Missing: FWC5503701 ‎' Must include: FWC5503701
PHILIPS fwc5503701 Audio System
Replacement Remotes https://www.replacementremotes.com > philips > fwc5...
Part Number: fwc5503701 ; Catalogue No.: 164697 ; Operating Manual Operating Manual Compatible with PHILIPS fwc5503701 Audio System ; Original Part Part originally ...
US$8.99
tip
How to Disable Philips Magnavox Demo mode
  • Many people are annoyed about demo mode coming out of nowhere and causing problems with many Magnavox televisions there is a simple process which will allow you to disable the demo mode.
  1. Television must be turned off But remain plugged in
  2. First You must place both your fingers on the VOL + and VOL - buttons on the television.
  3. Then Turn on the television while still holding the volume buttons in for about 6 seconds..
  • The demo mode will now be disabled, Some televisions may turn off after demo mode is disabled just use remote to turn television back on or use programme up and down button on television to turn it on.
  • This will work even if you don't have the original remote as it requires no remote at all its a simple process and it will work with nearly all models of Magnavox televisions.
How do I program my Magnavox universal remote to my Philips Magnavox fw530c mini Hi-Fi stereo
To program your Magnavox universal remote to your Philips Magnavox FW530C mini Hi-Fi stereo, follow these steps:
  1. Turn on your Philips Magnavox FW530C mini Hi-Fi stereo manually.
  2. Press and hold the "Code Search" button on your Magnavox remote until the indicator light turns on.
  3. Press the "Device" button on the remote, which should be the button corresponding to your stereo.
  4. Enter the 3-digit code for your stereo. You can find a list of codes for Philips Magnavox products in the user manual for your universal remote or online. If you do not have the manual or cannot find the code online, try entering codes 006, 007, 010, 011, 013, 016, 027, 033, 035, 043, 066, 087, 089, 114, 117, 118, 119, 120, or 123.
  5. Press the "Power" button on the remote to see if the stereo turns off. If it does, you have successfully programmed the remote. If it does not, repeat steps 2-4 with a different code until you find one that works.
  6. Once you have programmed the remote to control your stereo, test out the other buttons to make sure they work as well (such as volume control, track skip, etc.).
Note: If you cannot find a code that works for your stereo, you can also try the "Code Search" function on the remote. This may take some time, but it will automatically search for the correct code until it finds one that works.
1helpful
Can't figure out how to change the time on the Fujitsu Ten am/fm cassette player in a 90-something model Toyota Camry. Please help!!!
You hold down mode button for 3 seconds then use selector knob to select time ,then adjust time to suit
If you need to turn demo mode off hold down mode button for 3 seconds ,select demo then turn knob to off
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.
http://www.apple.com/ipod/car-integration/ http://www.pcmag.com/article2/0,2817,1865467,00.asp
17helpful
2answers
How do i turn offthe demo mode on a philips
On any appliance that has demo mode the solution is usually to hold down the stop button for like 3 seconds.
7helpful
CANCELLING the demo mode
Once the demo has started, press the STOP button on the front panel for 3 seconds. Demo will stop and the unit will enter standby.
You can download the user manual here:
https://www.p4c.philips.com/files/f/fw-r7_22/fw-r7_22_dfu_eng.pdf
6helpful
4answers
Magnavox 27
THANKS FOR THE INFORMATION ThaMp3DOCTOR. PRESSING THE VOLUME+and CHANNEL+ SIMULTANEOUSLY FOR 5 SECONDS WORKED!   THANKS
2helpful
Magnavox 27" in the demo mode.
To exit from factory mode, press the 'VOLUME(-)' and 'CHANNEL(-)' buttons on the TV set simultaneous for 5 seconds.
2helpful
3answers
Demo
will have to get u oginla remote uw ant me to help u look for it mark me as fix ya
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
