Model 91195298990. We replaced the main control circuit board upon advice from a local appiance repair. It didn't correct the problem. We tested the voltage at the breaker, plug and the back of the stove and all are 240 which is adequate. All the burners work on high but will not come on at low temperatures. Thought about infinite switches but this stove has four. Could they all be bad? What do you suggest that we try next?
SOURCE: My Kenmore glass top range,
SOUNDS LIKE YOU MAY HAVE A WIRE BURNED. CAN YOU USE A MUTIMETER?
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
SOURCE: Blank Display on Electronic Oven Control
If the burners are working it is not the circuit breaker as both use the same circuit. The board does use the ground or neutral wire. I would check that and see if there is 12VAC supplied to the board. If there is then it would appear you have a fried board.
Eric
