Braun MR 550 M MultiQuick Handheld Blender Logo
waleed hussien abd elraouf Posted on Jul 09, 2012
How to open braun 4191 body - Braun MR 550 M MultiQuick Handheld Blender
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 21, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3861
Points
How to open braun mw9045 hand blender. Any got idea .. Help me pls..
Did you manage to do it? I have the same blender, so same question.
Replacement parts
Part 2: Opening up the Braun handheld blender/mixer turbo 600, typ 4191.
A second phase, with the Dremel for working in the direction of the axis and splitting up the tools mounting part, also showed that no other way was available to open the machine7be945c4-ba75-4b59-83da-fc638caa551e.jpg
5helpful
Looking for somebody to repair my braun blender in Cape Town
Part 3: Opening up the Braun handheld blender/mixer turbo 600, typ 4191.
The front end and the motor are a cast-joint part. With one more circumferential kerf, the grip-part came free, also showing that there is no other way to open the machine irreversibly.
It also showed that the contacts between the motor and the print are/were relatively loose, which amazed me for a motor of 600 Watt. And in my case: they were burnt. That explained the machine not working. It is surprising that the thermal safety didn't kick in when my wife used the machine
6helpful
Braun type 4191 blender shaft coupling faulty
I had the same problem, the authorized service told they cant fix it, so i tried it. First, I show you the solution:
You see the black one you attach the heads to. The axis come from the motor with the little teeths: the black plastic wore away that's why the motor works but the end doesnt rotate.
You can simply pull the black one out with a pliers with medium force and if you get a new one(thats the hardest, they wont sell you) that will works.
For the mankind, ive totally flatten out my type 4191, so i show you some pics, how to solve yours:
if you had problem with the motor, simply cut it half. You wont harm anything, the motor is in a metal cylinder.
If you have some promblem with the electronic part, its in the end of the blender. You can open it at the top, but you cant reach anything form there, nor here, sad story.
finally some photos from the bottom:
Enjoy it!
3helpful
I believe that the motor of Braun MR 5550 CA MultiQuick Professional Handheld Blender is burned from electricity overload and i want to ask if this motor can be opened to be repaired & how this can be...
The motor in Your Braun MR 5550 CA can not rewinded like other motor in some equipmnets like motos in grinders for example.
You need a new motor but their always a question before you proceed you must ask the total cost including labour since this might be very near to the price of brand new blender. Just chect it out.
Good luck
I want to replace the flex on a Braun MR 5550 series. I have opened the lid but the way to replace the flex is none too obvious and I don't want to prise anything in case I break it.
Hi.
We can solve this difficulty with your any Braun Product in Bangalore. Spare Parts also available.
We are the Authorized Service Center for BRAUN in Bangalore.
Our Add.
Home Tech Serivces
# 43, 1st Floor, 1st Main, 2nd Cross, 3rd Block,
Basaveshwara Nagar, Bangalore-560079
Our Contact No. is - 080-40901310
Cell.No.: +91 97404 00030
28helpful
2answers
14helpful
4answers
How can i open my hand blender
Unplug it first and with a flat-head driver prise open the top between the flex and the top.
45helpful
6answers
Braun blender 4191 motor part does not work. fuse is alright. cannot open the cover in order to asess the damage. please advise.
My GF broke our Braun handheld mixer type 4191 500W, trying to mix some figs, the mixer doesn't do anything anymore. I like the mixer very much. I poked a while trying to open it and look what is wrong. This is what i found to open it. On the top, where the numbers are to adjust the speed: remove gently that lid. Below that you'll find 2e lid with the numbers on (1-5), this you can get open by pressing inside the 2 holes with 2 little screwdrivers, push these 2 black tips away and the 2e lid can be removed. Unfortunately i broke my mixer up trying. Now it's open i see how it was. Good luck guys
30helpful
2answers
Braun 600 tyrbo hand blender
Unplug it and with a flat head driver prise open the lid a the the top between the flex and the top cover
Top Braun Blenders Experts
Mike Cairns
Mike Cairns
Amy Smith
Amy Smith
Are you a Braun Blender Expert? Answer questions, earn points and help others
