Every time a load get's done the dryer with beep 5 or 6 times like a fire alarm, love the dryer, but the beeping is getting on my nerves.
The responses here miss the issue: The beeps described by the Poster are NORMAL and signal a finished load. However, the beeps are very loud, persistent, and extremely annoying, therefore the Poster wants to DISABLE the beeps. The question is how to disable the annoying beeps.
SOURCE: Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
SOURCE: Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
SOURCE: My Frigidaire FEQ1442ESO Dryer
Unplug it.
Remove the 2 screws on the back side to get the top off.
Slide the top off and take the 2 control panel screws off lift up the control panel and get he tech sheet out. Consult it to find out about them beeps. Use this LINK to access service videos for your machine.
Helpful?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Dryer gets hot, but not drying clothes
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
4. Moisture Sensor
Most units will have a moisture or dryness sensor as well that will fail. inspect the sensor for faults. replace if necessary.
1. Disconnect power
2. Open back panel
3. Remove control panel
4. Look for black buzzer about 5 nickels tall (control panel will say buzz next to this.
5. Use needle nose pliers and pull buzzer out.
6. Reconnect everything and enjoy a buzzer less dryer.
1. Disconnect power
2. Open back panel
If you open up the panel and unscrew the circuit board and look for a small black cylinder (pic below) that's the little annoying guy. Yank him out and your Encore will be silent. The auto wrinkle saver on this model must have been conceived by a deaf madman.
