I am stuck on the arm of cronos in the pit of tartrus what do i have to do next
Im on the arm of cronos and ive beaten all the skeletons cronos just keeps blowing air or slapping his arm. the arm has steel bands at each end and i cant work out what ive got to do or go
Re: i am stuck on the arm of cronos in the pit of...
You have to roll dodge out of the way when he slaps his hand and pull off his finger nail. then you go up to it and press "O" to grapple on to him and the fight will proceed from there. Hope this helps.
Check for something blocking the rising ghost. It really sounds like you might have a leak someplace. Check for holes or tears, especially on the seams. I have found clear packing tape works pretty well for a temporary fix.
The tie rod is a tapered fitted once the castle nut is off a pickle fork is beaten into the space between the rod and steering arm and falls out . no pickle fork then look for the raised portion on the steering arm smack it there 3-5 times hard it should fall out if this does not work suggest a 2 jaw pull and press the stud portion out . good luck.
The easiest way is also the messiest. Remove pit-man arm nut,Mark the pit-man arm and shaft with a colored marker,to assure you reinstall the arm in the correct position.use a pit-man arm puller to remove pi-man arm.When you get off the shaft,swing it out of your way,leaving the other end connected.Looking up in the steering box you will see a snap ring that you need to remove.When you get it out of there,reinstall the pit-man arm and nut to the correct position but don't tighten completely.Now refill the power steering box with fluid and put the cap back on the steering box.Put a pan under the pitman arm to catch the fluid.Start the engine and turn the steering in one direction as sharp as it will go,you'll here it in a bind but hold it tight,Then turn the steering wheel the complete opposite direction and turn it tight.This will use the power steering to blow the seals out! Shut engine off,look under car and your seals will be pushed out but held in place by the pitman arm you reinstalled.Now you can remove the arm and REMEMBER how they came out,just incase there is no picture instruction with your new seal kit.
Just curious, why do yo9ur run water from a tank to a pit?
Where is the pressure switch located? At the pump I presume? What will increase the pressure? If you are pumping to an open pit, you will never build up any pressure? What is supposed to restrict the pump to create pressure?
You need a restriction to create pressure to turn off the pump. Is there a float valve like in your toilet in the pit? If not this would be required
alrite well ive beaten gears countless times and all you have to do is grab the torque bow and shoot ram in the chest. the bats roaming arounf him will scatter and then you take out your sniper and snipe him out in the head. depending on what difficulty your playing, you have yo shoot him a certain # of times untill he dies. add me as a friend on live. my gamer tag is
brandonian458
oh and by the way STAY IN THE LIGHT. DONT GO IN THE DARKNESS OR ELSE THE BATS WILL OWN YOU. happy gaming!
