Question about Sanyo AVM-3680G 36" TV
Popping noise My tv is not old approx. 2-5 years. It is making a horrible popping noise. It is connected to a cable box and all cables are dust free and tighten. I have tried to turn volume down on tv and up on cable box. This is not helping. The popping noise is constant and quite often. Is it time to buy a new one or is this something that is worth getting repaired? Or better yet why the popping?
    Novelist:
    Champion:
  • 236 Answers
If the popping sound is NOT coming through the speakers, you probably have high voltage arcing. Probably close to the high voltage (flyback) transformer. If this is the case then other parts could be damaged if allowed to continue. If the popping is coming through the speakers then you could have a problem any where in the signal circuits. Like a loose connection. You'd need to have it checked out to find the problem.
Posted on Mar 03, 2007
SOURCE:
I have a Samsung Tv not even 2 years old it's making a popping noise now but only when I'm watching cable. When I watch Netflix it doesn't do it. What could be wrong?
Check your cable ends, also try to find where the sound is coming from! if it is inside the cable box you need to call the cable company for new box! You may have a short! in box or cables!
Jul 13, 2017 | Samsung Televison & Video
I recently purchased 4 K 22 soundboard for myself and my son and daughter.
i will put a pic here on how to connect the 2 tv-s
capture-wwsozecm2jr4f23puaylicsu-2-0.png good luck!!!
Apr 11, 2017 | Samsung Televison & Video
The menu screen keeps popping up why is it doing that and how can I change this so it only pops up when I want it to. My TV is less than a year old.
Is the menu screen popping up or the display information? Are you connected to a cable box or satellite tv receiver box? If you are you must be connecting to the television with what is called a coaxial cable, coax for short. When using that one cable antenna as people call it (has a needle in the center and usually twists to the right to tighten onto the television) this happens. If you have a cable box or satellite tv receiver box it may have colored holes on the back of it (green, blue, red, yellow, white, red, etc.). If this is the case you would need to connect to the television with composite or component cables which can be gotten from the drugstore, big box store or electronics store. Then you would need to switch av inputs on the television itself to view your tv channels.
Jul 27, 2010 | Televison & Video
Popping noise from speakers
You have a problem indeed. try lowering the tv volume . if the signal is too high on tv it can cause some problem with the sound system if that dosent work then you may have some electronic sound output resistor problem.
Aug 15, 2009 | Teac DC-D6300 CD Shelf System
Sony Bravia XBR-2 32-inch LCD with popping noise problem
Unfortunately, we have the same problem. We hear popping and our sound goes lower. It is not the cable box for us, it's definitely the TV; however, it happens, on our set, after its been on for a few minutes and then goes away after half an hour or so -- however, this evening its been happening for the past hour and the TV has been on for the evening.
Jun 10, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Popping noise
Our Sony (almost new) is experiencing sound problems. The sound go off and on about every 10 seconds. Cords appear correctly connected. It sounds as if its coming from the television.
Can you help with this problem?
Thanks,
Mike
Oct 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Has anyone heard of something like this where the cable box/service is causing popping sounds? yes & it is common problem. And is this something I should be concerned about causing damage to the TV's speakers? not at all. The Sony tech-support representative (over the phone) diagnosed it further to a problem not with the TV but with the cable box/service because there were no popping sounds when I played a DVD on my Playstation 2 that is attached to the TV. they are right that your problem is not due to tv. it is due to cable box/service? yes but not defective it reqires to change the way you have connected tv to cable.please call tech to get it connected in such a way so that you do not get popping sound when you you put off cable box.
Sep 23, 2007 | Sony FD Trinitron KD-36XS955 36" TV
Ghosting and popping noises
slag, Has the cable signal been branched off to another TV (or more) from the same feed? Ghosting and shadows are usually the result of bad impedance matches on those lines. Try connecting the prime TV directly to the cable box (or cable jack) output and note if there is any improvement. Make sure the cable itself is of the RG-6 type (not RG-59) and has no sharp bends or kinks. The center pin of the cable should be clean without corrosion. The RF IN jack on the TV should be checked to make sure the threads for the connector are clean and the plug should be attached firmly but not too tight. These steps should help solve this at least assuming the cable signal is good. [Checking it shows the "level" coming off the pole, not necessarily the quality of that level.] Hope this helps.
Oct 31, 2006 | Toshiba 34HF83 34" TV
Sanyo AVM-3680G 36" TV Logo
738 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
