My hotel room ac is blowing cold air just not strong enough to cool entire room
I am in Florida on business and I'm staying in an extended stay hotel my AC was working fine until a week ago I woke up covered in sweat. When you are by the unit you can feel the cold air but its fan isn't blowing strong enough to properly cool the entire suite. I called maintainance and they said they could feel the air but coming in from the heat it feels cool to them BC it is hot outside but when you are inside it is diffirent they just ignore when i keep calling I have to keep my lights off at all time the unit is also making a loud sound like a struggling rattle is the best I can describe it please help! I am overheating!
  • andrea Jul 09, 2012
    Its brand is carriee
    Carrier
    Master:
  • Heating & Co... Master
  • 523 Answers
It may be frozen over. At the front of the unit there should be an air filter. May be behind a panel that opens, or it may slide out. Behind that filter will be the indoor coil or evaporator coil. Look to see that coil and if there is any ice on it. It will be a white ice covering the coil. If it's frozen up, turn the cooling mode to off, turn the fan mode to on, and let it run at least a couple of hours to thaw. Let maint. know it's frozen up and needs service. Get what you pay for! If it's not frozen up, find some way to check the supply air temp. Some sort of a thermometer. It should have a 50-60°f supply air temp, depending on the indoor temp. Most I've seen will supply 45°f, but 50-60 is a good reference. Hope this helps! I bet it's frozen up.
Posted on Apr 06, 2017
SOURCE:
  • 86 Answers
SOURCE: Stand alone AC blows cool air but does not cool the room
send tank capacity.model mail me mintex007@yahoo.com
Posted on Mar 17, 2008
22yooper
  • 828 Answers
SOURCE: Heat Pump
Your inside cooling coil in the air conditioning mode could be frozen over. Change the fan setting to on and operate it that way when in the cooling mode. Turn the air conditioning OFF with the fan ON to clear the coil of frost which should take about 1 hour.
The fact that you have sweat on the large line means that the temperature of the gas inside the line is below the due point of the moisture in the air. A good tech would measure the pressures and temperature of the system to get what is called superheat to determine proper system charge of refrigerant.
Posted on Jun 14, 2008
22yooper
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
  • 233 Answers
SOURCE: our ac just suddenly stopped working. the fan
probably from the symptoms you describe the condenser fan motor has failed.If the fan is not running and the copressor is you need to shut the power off to the unit until it is repaired, the compressor can susstain damage from the lack of fan, and it is the most expensive component in the system to replace...
Posted on Aug 15, 2009
  • 1796 Answers
SOURCE: Turned on AC was running fine. 30 minutes later
Hi!!
This means that the condenser fan motor (outside unit) failed, this caused to build hi pressure and either activated a safety valve to release the extra pressure or blew a line and R22 Refrigerant escaped from system.
The fix is to replace motor fan and capacitor find the leak and refill system with R22 Refrigerant Gas. It is safe to turn on the Fan Only mode on the Thermostat until a HVAC Tech arrives.
To perform this job parts and labor included will cost: about $300 -.$400. Look on the Yellow Pages for a Tech in your neighborhood.
Good Luck!! Don't forget to Rate this post!!
Posted on Aug 13, 2010
Sometimes it blows out warm air warm enough to warm an entire room, yet at other times is blows cool air that can kkep a room cool. I want it to blow cold at all times. how do i do that?
dry air feels cool on the skin
moist air feels warm on the skin
this is why the perceived temperature of air from unit changes
Apr 14, 2015 | Dehumidifiers
Tip
Book your Bangkok Hotel & Feel the Thai Charm
The thriving city - Bangkok welcomes tourists to a vibrant, fascinating, and colorful experience which at times can even get mind-boggling. The Bangkok hotels dot the landscape alongside glinting skyscrapers which poise the city.
Bangkok, the land of smiles, has something in store for each and every visitor. The only prerequisite being proper research, before determining on a hotel which best suits one's taste, mood, and budget, to make the experience surreal and unforgettable.
You may wonder - Can Bangkok gets any better and cheaper at the same time? With crazy & tough competition between hotels, you can expect prices to get equally competitive too. In these pocket-friendly packages, you might not get concierge services.
Let's have a glimpse at these uber cheap hotels in Bangkok!
1. Hotel Urbana Sathorn
Without the high price tag, this all-suite hotel might just be what you're looking for in luxury. The rooms are very spacious with lavish tropical designs that bestow it a polished, elegant look. Every room has its own kitchenette, some with living and dining areas, with the added extravagance of a balcony. In order to make your stay even more special, you can book a room on a higher floor for a backdrop of Bangkok's skyline just out your window!
The hotel is 0.6 kilometers (0.37 miles) from both Lumphini MRT and Silom stations and just 9 minutes away from Sala Daeng Skytrain station, so you are able to travel around to different parts of Bangkok efficiently and conveniently.
2. Oaks Bangkok Sathorn
Oaks Sathorn hotel rooms are polished and luxurious and are well-decorated and spacious, giving you a very comfortable, homely feel, where you can relax after a long day. Chong Nonsi BTS station is just a 10-minute walk away; however, if you aren't feeling like a walk under the hot sun, Oaks Sathorn hotel has an hourly shuttle to the station for your convenience.
Enjoy great views from the infinity pool on the city view terrace, or from the Zoom rooftop bar where stunning night city views are abundant. Staying at Oaks Sathorn will give you a different view of Bangkok's chaotic, busy life, offering a quieter experience with popular shopping and sights still close by.
3. The Berkeley Hotel Pratunam
'Prime' is the best term to describe The Berkeley Hotel Pratunam. Guests can find nothing short of convenience when you stay here. The rooms are elegant and roomy. The hotel is just a quick 2-minute walk from Pratunam Market, and ultimately it is close to almost everything else you may want. If you can't get enough of the city, this is a place to definitely check out. Not only do you save on accommodation here but also transportation, so you have more funds to shop, shop, and shop!
4. Anantara Sathorn Bangkok Hotel
Enjoy panoramic views of Bangkok from your balcony with a fresh cup of coffee from your room's coffee maker. The 5-star hotel is just 15 minutes walk able away from Chong Nonsi Skytrain station. The rooms are spacious and well-designed with floor-to-ceiling windows, clean-cut furniture, pops of color, and Thai-style prints. Both rooms and suites are equipped with coffeemakers and mini-fridges for your everyday use.
5. Grand Sukhumvit Hotel Bangkok
Grand Sukhumvit Hotel Bangkok has a lot for you to do around the hotel. The rooms and suites are spacious bright yet cozy, with amazing views of the city. The rooms are hygienic and use neutral browns and bright whites that give the hotel a chic look. A grand, tropical-feel outdoor pool welcomes you on a hot sunny day, where you can cool down.
Well, Bangkok offers an incredible array of cheap & lavish hotels to choose from, but we know how tedious it can get to keep searching for the perfect accommodation. Especially, one that comes at a good value for your hard-earned bucks.
Whether you opt for creating lifetime memories with your dear ones, or with a group of friends, these Bangkok hotels will not fail to impress you! Stay at one of the best cheap hotels in Bangkok without the pain in your wallet.
Visit:
1950 Hotels in Bangkok Flat 10 KWD OFF on Bangkok hotels booking
on Dec 06, 2017 | Luggage & Travel
Tip
How to cool big home with small air conditioner(s)
A lot of people have only one or two rooms that can take an air conditioner in the window. Often times, the air conditioner is also rated at a cooling power that would make you believe that there is no way that it can to cool the whole house/apartment. You can crank it to the max to try to cool as much as possible, but then this makes one room too cold and the others still stay too hot. You can try blasting the cool air down a hallway with a fan on maximum speed, but that only works so well. And, it's noisy, too. Well, I have two 260 sqr ft rated room air conditioners and I am cooling 2000 sqr feet of house to a comfortable 72 degrees in all rooms and it's been 95 outside all day. How to do it?
The trick is setting up your home to take advantage of laminar air flow. Set your air conditioner to say 68 degrees and start it in the middle of the morning before it feels hot outside. Put the AC deflectors pointing downward and towards the door. Put fans in the doorways pointing out of the rooms that have the AC. Point them level to the floor (not up) and put a fan to one side near the end of long hallways. Set the fans on the lowest power setting (not high). If the hallway branches out into a bigger room, put a fan in the room that is blowing across at a right angle to the entry, pointing the air flow parallel to the wall. This will circulate the cool air around the room. Keep the fans on low and pointed parallel to the floor, not up!
What you have created is a re-circulating air flow system, much like the North Atlantic Current that moderates the temperatures of Europe. You can check this by taking a tissue paper and holding it up to the top of the doorway. The air flow should be pushing the tissue away from the room without the AC and toward the room with the AC. This happens because the warmest air will be toward the ceiling and you want that warm air to make its way across the ceilings and back to the room with the AC, so that it can be cooled again. The cooled air from the AC will sink to the floor and the fans will gently push the air out of the room with the AC. It will stay low and travel along the floor in the opposite direction and into the warmer rooms. If you crank your fans up, you will create turbulent flow and that will not cool your house as efficiently as will laminar flow. Monitor the outside temperature and when it gets cooler outside by a few degrees, turn the AC to fan for about 10 minutes to eek out the last of the cooling. Then open the windows for the night to take advantage of the free cooling that nature provides. That's it! Enjoy the summer!
on May 25, 2015 | Heating & Cooling
My 1995 gmc 1500 ext cab siarra 's ac stopped cooling, i put at least 2 1/5 cans in it about three weeks ago, it was running fine until a day ago, please tell me what is wrong, is it compreesor re
You have a leak,to see if you do,get a spray bottle,put soap water in it and spray all a.c.lines and see if it bubbles up any where.Look for usual stains at connections.
May 25, 2013 | 1995 GMC Sierra C1500
I have an LG RH387 that stays on the 'hello' message.
You will need to remove the cover and inspect the capaciters, look for the cap/s that have expanded on the cap.and replace, If your not too happy at soldering look on YouTube for guidence, Make sure the larger capacitor are discharged with mains supply unpluged.
Sep 10, 2012 | LG RH177 DVD Recorder/HDD Recorder
My ac is not cooling off the room like it used to. It still blows cold air just not enough
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 24, 2011 | Heating & Cooling
Luckywire isn't connecting. I tried redownloading it several times but it still doesn't connect. Help please!
Depending on your ISP, you may have blacklisted and blocked. Yes, your ISP can see what you're doing and shut you down if you're using a P2P and it's very easy to spot. My company acts as an agent for an ISP and we do it a dozen times per week at extended stay hotels.
Apr 25, 2011 | LuckyWire
I live in a very small one room studio,and have a comfort aire window unit...air and heat.The heat works real well,but in the spring and summer,I would set the unit on the coldest setting.I can hear the...
Lets look at the output of the system first. Take your square footage of the area you are trying to condition and times it by 15. We try to get 15 Btu's per square foot of air conditioning. If your area is say 10 by 15, you have 150 square feet; times it by 15 = 2250 Btu unit is required. If you have a 5,000 Btu unit, it should be more than enough to cool the room. If this is correct, the problem may be because you have the unit set for Dry. In Dry mode, the compressor will cycle less frequently than if on Cool. If in fact the unit is on Cool, you may need to lower the temperature setting to fool the sensor from turning off the compressor prematurly. If you still can't cool the area, your unit has an issue with either refrigeration or air circulation and will need to be serviced.
Apr 09, 2011 | Comfort-Aire Heating & Cooling
Heating & Cooling Logo
476 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
