SOURCE: please help!!!
Try the remote's "search" feature. If that does not work, then the remote doesn't have a code for that unit.
Hope that fixed ya...
Geno
SOURCE: In need for remote code number(s)
Yes I have solved my problem. Thank you very much for the help. I came across a web site that gives you the TV codes so I can program my Direct remote.Thank you again.
SOURCE: I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
