Question edited for clarity.
Question moved from Televisions category, to a Rascal one.
Go to the horn and note the colours of the wires. They can go on the horn switch anyway around. Do the same for the light. No wiring diagrams exist online for that model.
I know a motability expert who lives near to me and solves all my problems regarding my motability scooter. His name is Stewart and his phone number is: 07846892398. He may not answer phone but do leave a message because he will always return your call. Hope this is of help. Good Luck
June
Hi, I've had the same problem with the Tomy WalkAbout Platinum - and, indeed, no help to be found on any website.
Eventually traced the problem to the temperature reset button on the child unit (the blue button to the side). This button was lodged solid in the device; on inspection because of the wire of the temperature sensor.
I've opened up the child unit (remove the four small screws with a watchmakers screwdriver) and removed the entire temp. reset button.
The set up works as normal (but with a bit of gap). With a bit more time, you might be able to fix the temperature sensor wire and get the temperature reset to work again.
haynes are really brief, try speaking to a yamaha dealer, sometimes if you catch the on a good day they can send you a diagram they use, failing that you can purchase a manual on ebay normally, and failing alll that, work back bit for bit on all wiring with an electric meter
