If the sound changes as the car goes quicker I would open up your diff cover and take a look inside for any damage along with making sure that your pinion hasn't loosened over the years.
You need a trained technician to listen to this, but it sounds like a connecting rod and or a crankshaft main bearing noise. I lean more towards the rod knock form a worn out bearing.
Bang on the catalytic converter being careful not to get burnt and see if it's loose causing a rattle. Until you determind what the problem is don't drive the vehicle. The other possibility is that you may need an engine. If what you're hearing us a connecting rid knock.
You may have damaged the engine. So that being said either a bad rod bearing or other issue may be something needing to pull the engine. How is the oil pressure. A rod knock is east to hear. To faster the rpms the worse the sound. Rebuild or replace.
The only way to determine what it is would be to remove the sump from the motor, Either way you need another motor as the cost to repair will be greater than the cost to replace.
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
First, check the belt (located in the bottom of the unit) and if it shows signs of wear (black dust) and shiny sides on belt and black marks on the motor, transmission, and water pump pulleys - replace the belt. The motor is spring loaded and acts as the tensioner up to a point of too much wear on the belt. You will need to tilt the washer about 45 degrees and prop it to keep it from going all the way over (just makes it more difficult to right it later). Pop the belt off by rotating it while pulling the belt off the edge of the transmission (larger) pulley. Again, the motor pulley is spring loaded and will flex appropriately. Reverse the process with installation of a new (exact replacement part number). If this doesn't fix the problem, you may have to call the Maytag Repairman. They would have replaced the belt anyway and would probably charge $50 + for the belt and installation.
