Hi there:
I suspect it is a exhaust valve guide problem. When an exhaust guide is loose in the engine or leaking oil, the oil never enters the combustion chamber. Oil drops through the guide and into the exhaust port of the head. The exhaust stream then carries the unburnded oil out to the exhaust. As the exhaust system warms up, the oil then burns off and leaves as blue smoke.
Remove the valve cover and take a flashlight and closely look at all the valve seals and guides, especially the exhaust guides and seals.
Check HERE for additional generic descriptions.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
