SOURCE: NetGear WNDR3400 N600 router set up fine, but it's
The wireless router has capacity to over perform only situation with the device connectoins to your computer are receiving signals from more than one network. You are allowing several signals to access the computer. Establish one network pass at a time. a stronger once should be chosen and the device would perfrom to capacity. The network setup need to be reconfigured
SOURCE: my netgear wndr3400 wireless router
change the channel selection in the wireless settings from auto to a any one of the channels on the drop down list. I actually did it by trial and error until the i found a channel that works. Also if you have the router on the ground floor of a multi floor home the signal range is lousy, move it to the second floor and keep it away from places where they are too many electrical devices close by maintain at least 6feet of distance from televisions and speakers and the range will be excellent
SOURCE: The region settings of my
Download the firmware update or same version from the netgear website, try to download a version for asia there.
SOURCE: Can't connect to the internet
I am assuming you HAVE connected before.
Here is how to fix that corrupted DNS cache in vista. 1. Click the Microsoft Vista Start logo in the bottom left corner of the screen Windows IP Configuration After that in the same command window type ipconfig /release ipconfig /renew That should clear up the issue. Odds are you were sharing an IP address with someone else on the network.
2. Click All Programs
3. Click Accessories
4. RIGHT-click on Command Prompt
5. Select Run As Administrator
6. In the command window type the following and then hit enter: ipconfig /flushdns
7. You will see the following confirmation:
Successfully flushed the DNS Resolver Cache.
SOURCE: I have a netgear wndr3400.
The router has probably provided too many IP address and assigned one out of your range.
If that doesn't work, I would log into the router. www.routerologin.net and under settings release your IP address or cycle your modem and then your router.
I am unfamiliar with the '71, does it have a full model #?
