I need to replace the nozzles as they have chipped over the years in my tub as we are getting ready to sell our house. Does anyone know how that it done.
Hopefully your tub is not too old because this will make replacing the nozzles very difficult as they are no longer made.
If in fact you have a Jacuzzi Brand bath you can get what is still available for bath jets here. The diagrams will give you an idea of how they come apart.
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
SOURCE: Not all jets working on Hydrosystem Whirlpool Tub
I believe the below web site can help you with your problem. The jets are more then likely just turned off.
I hope this helps.
sanray
http://www.hydrosystem.com/hydro4/options/components/
SOURCE: How to Change White Water Whirlpool Tub Jet Hardware
First step is to remove the old hardware so you have something to compare it to. THere are two types/sizes of tub faucets on the market for deck mounted applications. If yours is mounted on the tub deck then it is a deck mounted application.
The faucet spread (distance between the threaded nipples on the bottom of the faucet) is going to be something close to 8" or it will be of variable distance. If the two handles and the spout are connected via hose then they are of variable length.
Bring the old faucet into the hardware store and compare it so you know you are getting the correct one. It is not hard but also not fun to have to adjust the holes in the tub deck to accommodate a different size.
AS for the suction.....I am assuming that you are referring to the inlet part o the pumping system and all of the equipment behind the tub. I always recommend that you use parts from the same manufacturer. It is extremely helpful to call them with all of the numbers you have to get a list of acceptable replacement parts.
Hope this helps.
I recommend that you consider spray painting the gold hardware with brushed nickel rusteoleum paint. IF you decide to go this route you must lightly abrade the gold surface with emery cloth then prime with rusteoleum primer, let that dry and the final coat will be the brushed nickel. I have done this and it turned out excellent. I get compliments on it.
Regarding your other issues, you will be happiest with white water parts. That being said, it is likely that locally procured parts might fit. I would get one set of parts and try them.
You will likely find the model number etc. on a plate in the mechanical compartment of the spa.
Thank you so much. This does help me
