SOURCE: how to set the temperature
Look up this fan on amazon.com. In the comments/reviews a gentleman posted instructions for fixing the thermostat (it involves opening up the fan and repositioning the thermostat wire).
THE RELEVANT PART OF THE AMAZON REVIEW IN QUESTION:
How to fix it:
WARNING: Before opening the back of the fan be sure to unplug it first! Don't electrocute yourself, please. Next, once all the screws have been removed open it from the side without the expander. You won't be able to take the back completely off but it opens wide enough to get your hand in there. Be careful. Don't blame me if you crack the casing or hurt yourself. Plus, opening the fan voids the warranty so proceed at your discretion. The thermostat wire on this model is a thin black wire about 3 inches long that is tucked under the circuit board on the right (if the top of the fan is closest to you when you've opened it). I stretched it out, taped it in place, and now it works like it should! When putting the fan back together the plastic part that covers the circuitry also houses the upper arm of the side extension so the arm should rest just inside the lip.
