You can speed up or slow down the clock by adjusting the length of the pendulum. This link will walk you through the process.
http://usedclockparts.com/9-clock-case-repairs/31-how-to-speed-up-or-slow-down-your-clock-using-it-s-pendulum
SOURCE: Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
SOURCE: i have my mother's seth thomas mantle clock
This clock does not adjust that way.
Hope this tip helps.
r/
David
SOURCE: I need a Howard Miller battery mantle clock
Try www.klockit.com. You can replace the entire movement for about $5 including new hands. You can select from an assortment of hands that will probably match the style of what you have and use those if the old hands don't fit the new movement. I've bought several movements from them over the years. For a few more dollars you can upgrade to an "atomic clock" movement which synchronizes with the US time signal and even sets DST automatically.
