Whenever you try to take a picture, you have to first press half the shutter. Then you should wait for the green signal which tells you it is focused. But in my case, a red signal shows up. And the camera says it is not focused, try again. After trying for a long time it may give you one green signal which will allow you to take a good picture.
SOURCE: I have a Sanyo VPC-s885 digital camera. I have
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
SOURCE: When I press the shutter button nothing happens.
look with a lens that to insert the cards, you dont have torque one of the little contact into the camera. and this contact dont touch with the other near contact. f touch one with the other keep out the batterie and with patience and litle force, with a needle, torque the contact to the right position. if you dont find this, i have fear that is a foul contact from the ccd eletronic flat, and this is a problem. that is possible if the camera is drop, have suffered a pressure. in this case if you dont have specifics knowledge, you cant repair the camera. why the camera must be opened, prove if the flats are did not move. and if this is not enough, its probably that you must change the optic. if you see the immage in the lcd but not pics, probably you can change only the optic without ccd.
SOURCE: What does it mean when
try to reset your cammera settings to default
try to change memory card first.
try to format your memory card
