Yes. You can take the filter bag off the Kirby. just press the button at the top of the bag to release the bag, and just unscrew it at the base... and hand was in warm water using some nice smelly detergent.... hang out in the sun to dry..... and replace the paper filter bag more often.... I need to as I have 3 dogs and the dog hair does smell after a few days inside the filter bag, so I replace the filter bags quite often to stop any smelling... Bugbuyer
SOURCE: HOW DI I REPLACE THE OUTER VACUUM BAG
do you mean you want to take the comple bag assembly off?
Just twist the boot. Its stiff, but it will come off with the bag
Twist the bag emptor left to remove it from the upright then your need a sharp narrow pointy object (like a metal dental pick cost $1 in most stores) push it under the plastic band around the rubber on the bottom of the cloth bag roll it across and take off the plastic tie once off pull the rubber bottom part of the bag emptor take out the inner plastic tube and zip the bag put in the washer by itself and wash with soap and softner and let hang dry you can also wash the inner plastic tube with hot water and fabuloso I recondition kirbys and do it all the time.
Here is a link to my guide for cleaning the Kirby cloth bag...
It should be helpful. :0)
Marci
