Have a brand new, well a year old FDB4315LFCO frigidaire dishwasher that was given to me,never been used just installed it there is water going to it but it never gets to the wands and it doesn't run the cycle i took out the motor and spun the impeller but that did nothing can you offer any suggestions? i got this dishwasher from a friend who purchased it but never hooked it up .
If the cycle does not run I say the timer is in need of repair/replacement. Go to site for parts Search Over 2 1 Million Appliance Parts
SOURCE: Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
SOURCE: Frigidaire FDB740RCS0 Upper Armnot Turning
Make sure the spout leading into the top spray arm is not obstructed at all. Maybe simplistic, but could be overlooked. Just thought I'd put it out there.
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
SOURCE: I have a dishwasher frigidaire model #FDB4315LFCO
you may have a water problem. if you dump a bucket of water in the tub after it starts wash cycle and the extra water makes it work. check you line pressure and if thats good replace your water inlet valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: My frigidaire dishwasher model # FDB4315LFCO, is
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Hello wladyka, that's a great question!
Normally, the spray arm would just screw into place on a Frigidaire dishwasher. If you continue to experience issues with the spray arm I would suggest consulting with a professional for further assistance. Hope this helps. -Matt
