Engine ran fine then just stopped running. Replaced fuel filter, and fuel pump. Check vacuum line for holes. Tank is full of fresh fuel. Pulled fuel line between carb and pump and poured gas in line directly to carb and it starts and runs until all gas is out of line. Thinking fuel flow problem from tank to pump??? Any ideas.
SOURCE: 22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
SOURCE: 18 hp briggs & stratton intek i can get it
Check the choke, if that doesn't work the old gas may have left residue that is plugging your ports.
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
