Sanyo Xacti S5 Digital Camera Logo
alyssa cannata Posted on Apr 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sanyo vcp503 i couldn't find my camera listed in the sanyo section so i am posting up my problem i got the camera for xmas i thought i was going to be ok i would have pictures for xmas well my memory for the camera only held a few pictures so i needed an SD card well i hadn't gone anywhere where the camera was needed until this weekend i got an SD card put it in the camera and everything went fine went out with friends batteries were low and eventualy died, i turned on the camera and turned it back off but the lens wouldn't open and the zoom wouldn't go to its full. i changed the battery today and still doing the same problem could the camera be defective?
Tony Parsons
Level 3:
  • Sanyo Master 6,405 Answers
  • Posted on Apr 07, 2017
Tony Parsons
Sanyo Master
Level 3:
Answers
6405
Questions
Helped
1650956
Points
20272
If the batteries died while the camera was in use, the probability is that there has been internal damage to the camera.
5 Related Answers
Anonymous
  • Posted on Apr 25, 2008
SOURCE: need help quick
you have a picture upside down if u turned a picture on ur computer put memory card in computer and turn picture how u took it decode error will go away
Anonymous
  • Posted on Nov 22, 2008
I had the same problem just this morning...but I fixed it!
If you have manipulated any of the files on your camera...by opening them on your computer and modifying them...then the camera won't decode them. This is because the dimensions change and exceed the dimensions of the camera. Try returning your pictures in your camera file to their original state and saving it to the camera. Don't forget to delete the ones that don't work. This should work.
Anonymous
  • 19 Answers
  • Posted on Jan 09, 2009
SOURCE: Zoom lens stuck out and camera will not power on...
Try another set of batteries
fotomohamed
mohamed salim shaikh
  • 321 Answers
  • Posted on Jun 18, 2009
SOURCE: Recharged battery, turn on, stays on about 2 seconds then off
its a batt. problem use NiMH enelop cell
Anonymous
  • 2761 Answers
  • Posted on Dec 07, 2009
SOURCE: I have a Sanyo VPC-s885 digital camera. I have
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Need manual to learn how to operate camera-vcp-t1495
I couldn't find the camera you listed, but there is a VPC-t1495. Here is a link to it:
http://www.retrevo.com/support/Sanyo-VPC-T1495-Digital-Cameras-manual/id/23843ag223/t/2/
If that is your camera, there is a link to download the manual on that page, or here is the direct link to it:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=a5b6f05a51d5b777e5dbf28be804a144&modelid=23843223&q=Sanyo+VPC-T1495
Thanks,
John Vickers
Aug 12, 2011 • Cameras
We bought a 7 inch black duronic photoframe for a relative at Xmas. We only found out recently they couldn't work it. Today I have tried. It reads the SD card from my wife's posh lumix camera...
there should be a reset button at the back of the photoframe. try push.
try to use a usb thumbdrive instead of sd card. copy some jpg files from your computer into it.
Jun 30, 2011 • GPS
1helpful
What does the E mean on the screen.I put a new film in at Xmas time and only took a few pictures when the E showed up and couldn't click the picture. took to camera shop replaced batteries and film ...
If you go to http://www.pentaximaging.com/support/manuals-and-literature/ you can find the manual for your camera. From my experience the E on a Pentax camera means the film isn't loaded properly. Hope this helps.
2helpful
I have a Hitachi HDC-1098E camera, the images are very grainy. please advise
Hey i got this camera yesterday aswell for xmas and i thought that but then i did some research and what you want to do is go onto user setting and then turn down the iso as low as you want because it lets in less lights if you turn it down and this stops it being grainy, well at least it did for me i hope it has helped
Lense errors
You need to go to the support section of the Sanyo website to find out what the error codes mean.
1helpful
2answers
Cannot get english on camers
Read the manual section which states setup or setup language. You will be given several options, then select English and return. Now your camera would display everything in English. If you do not have your manual go to this link to doanload it.
http://camera.manualsonline.com/manuals/mfg/sanyo/vpce760.html
Or call Sayo for help link here
http://us.sanyo.com/Handler.aspx?404;http://us.sanyo.com:80/Customer-Support
Good Luck!!!!!!!
How can I get rid of the delay on the shutter release?
this is just the lag time of the camera..nothing you can do about it...sorry
Need manual for sanyo vpc-t1060
You need a manual for the VPC T1060? This must be a camera no longer supported by Sanyo. I went to the website to get your manual, and I can't find it listed anywhere. You posted this question under the VPC T700 catagory. Is that the model you meant to get? If so, the link for the manual is here.
http://sanyoservice.com/pdf/images/VPC-T700.pdf
Good Luck,
Rob
1helpful
2answers
Can't download photos to computer
did you turn of the camera?
the camera need to be on for the PC to detected the memory card.
you also going to need the Arcsoft PhotoImpression software. However, the software is going to cost you $40. if you lost the CD that came with the camera.
you should be view the photo with any of teh photo software you have on the machine.
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
