SOURCE: how to set electric clock on 2003 yamaha roadstar silverado
hold both buttons down @ same x. they will start to blink. hit left button once and hour will blink. use right one to go up. repeat for mins.
check the fuse pos under the panel
SOURCE: Paint codes for 2005 Yamaha Roadstar Black & white
http://www.colorrite.com/matrix-colors.cfm?CFID=1620536&CFTOKEN=74145802
Go here my friend.
Bob
SOURCE: Yamaha Roadstar 1700 Midnight sticky shift lever
make sure linkage is adjusted correctly. dry lube the levers moving part
SOURCE: describe seat removal on 2004 yamaha roadstar
roadstar seats remove from the key switch, turn left "without" pushing down on the lock cylinder, and you will hear the seat release from the front of the drivers pad.
