SOURCE: How do I reset Canon MG 4170 ink level
I have not used your particular model of printer or these specific cartridges, but the UK versions of these cartridges cannot have the ink level estimate reset. However it is not necessary to do so to continue using these cartridges.
Instead when the cartridge believes it is empty the printer will ask for a prompt from you in order to continue printing (usually in a rather lengthy message). We made a short video on the subject:
SOURCE: how do i reset the ink level in my printer: canon
the ink level setting is in the ink cartridge, many cartridges require you to change the chip in the cartgrdge, but in some u can use some simple tecniques to reset the levels....search in google based on ur printer cartridege model number.
SOURCE: how to reset ink level for canon mp545
Try this it works for canon mx300 may work for you
1. Disconnect the power cable.
2. Connect it while holding down the "power" button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button.
5. The printer turns into factory mode: wait for about 10 seconds, then it says "Idle".
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning". A test page will print..
9. Open the cover, like you are about to change the cartridges.
10. Disconnect the power cable again.
11. Take out both cartridges.
12. Close the cover.
13. Connect the power cable once again.
14. Turn the printer on.
15. Put the cartridges back.
SOURCE: how to reset ink level after refilling canon mg 5220
You should not have to reset anything. When you put in the cartridge and snap it into place, it should automatically reset. If it did not, make sure you removed the plastic and that the cartridge is snapped into place and the red light is on. If you're still having problems, let me know.
SOURCE: reset ink level for printer canon pixma ip1980
http://indoresetter.blogspot.com/2008/12/resetter-printer-pixma-ip1980.html
go to this link and download resetter......
