Yes, there is. You can find information about it here: http://en.wikipedia.org/wiki/DDR_SDRAM
If you want real help, know your motherboard's brand & model so we could check what type of RAM it supports. If you can't find out, download and install speccy or aida64. It could give detailed report about the specs of your pc.
Hope this helps.
If you added another 512Mb RAM to increase the RAM to 1Gb then the new 512Mb memory stick could be incompatible with the original 512Mb or it could be faulty. Use RAM that is same make and speed as the original RAM. Remove both RAM and just insert the new 512Mb into your laptop and see if the laptop boots up, if not then the RAM could be faulty.
Windows 32 bit supports up to 4GB, but will only give 3GB as usable. 64 bit is a whole different story, but keep in mind that most software is not written for large amounts of RAM.
Product Details Kingston DDR2 800 2G Memory Ram 1).Capacity :512MB.1GB.2GB 2).Model:KVR800D2S6/2G 3).Interface :DDR2 SODIMM computer ram,memory ram,laptop ddr ram,memory module Product Description User Rating: 0.0/5 Kingston Technology Kingston ValueRAM Computer RAM 2 GB - of DDR2 SDRAM, KVR800D2S62G KVR-800D2S62G KVR800-D2S62G KVR-800-D2S62G KVR800D-2S62G KVR-800D-2S62G KVR800-D-2S62G KVR-800-D-2S62G KVR800D2-S62G KVR-800D2-S62G KVR800-D2-S62G KVR-800-D2-S62G KVR800D-2-S62G KVR-800D-, ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices. Product SpecificationsModelBrandKingstonModelKVR800D2S6/2GType200-Pin DDR2 SO-DIMM
unplug the power adapter and remove the battery from the laptop
1. Remove the two screws fastening the RAM cover. 2. Detach the RAM cover from the main unit. 3. Pop out the memorys and remove the memorys from the memory sockets.
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
If it has 4 slots and supports 2Gb max with 2 slots currently populated with 2 x 256mb chips you'll need to remove both those chips and install 4 x 512mb chips to reach the max of 2 Gb.
