You don't say which model you have but if it is a radio controlled watch, then try re-setting the location, it frobably "forgot" where it is and wen back to the original factory setting.
Place the watch near a window that faces Colorado. best reception is at night although you should get a signal during the day where you are. The signal comes from a transmitter in Colorado. Also, make sure your watch is a model with the US frequency as there are different frequencies used in other parts of the world. Read more at http://www.ntp-time-server.com/atomic-clock.htm.
ok place watch on window ledge inside house ..when you go to bed make sure its sat on a book with nothing else in its way except the glass window, the signal should be picked up by your watch between midnite and 3am that is sent from one of 5 world wide beacons.if this does not work have battery refitted and make sure the repairer AC's the watch this has to be done any repairer will know what you mean..
Alhamdulillah, the problem solved (at last) tks to IRONMAN
(http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this : 1. Pull the crown full, and turn it clockwise until you find the right day. 2.
and then push it one click (dont push it to hard so it back to normal
position) and turn the crown counter clockwise to adjust date. 3. Push the small button near the crown to adjust month.
I've just worked it out! Change month....depress inset button on side above hand winder. One push with cocktail stick or similar will advance month. Change date.....pull out hand winder half way, turn knob anti-clockwise until desired number is met. Change day...... pull out hand winder fully, turn clockwise passing midnight repeatedly until day is set, continue to set time, keeping an eye on 24 hour display for am/pm.
All the best, Bob
