Toshiba Satellite A65-S126 Notebook Logo
Posted on Jul 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the master reset button - Toshiba Satellite A65-S126 Notebook
Kevin Satterwhite
Level 2:
Scholar:
New Friend:
  • Expert 67 Answers
  • Posted on Jul 07, 2012
Kevin Satterwhite
Expert
Level 2:
Scholar:
New Friend:
Answers
67
Questions
Helped
14769
Points
174
There is no master reset button for a laptop. You can use your recovery feature (if available) or use the disk that came with the laptop to reinstall the software. Either option will give you a fresh start.
Resetting Master pin on rona Electronic Deadbolt lock
Google
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
Remove batteries and put them back. You will hear a long beep and a short beep.
Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
Key in master PIN and press UNLOCK button
Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
Release 0 button and you are in the Add PIN mode
Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
make model resetting lock
https://www.google.com/search?q=resetting+Master+pin+on+rona+Electronic+Deadbolt+lock
2answers
I want to reset the Samsung ezon shs5120 password
Reset master Pin Samsung EZON Home Systems shs-3120? How do i reset the master Pin for Samsung Ezon Touchpad Door Lock SHS-3120. I tried to follow instructions written in the user manual but it doesn't work. I have forgot master PIN and factory reset for deleting all the users(as mentioned in manual) and setting the master Pin to default value of 1234 is not... show more
Update: I found the answer/solution
1. Press Initalizaion button on the indoor unit.
2. Press Set button for 10 Seconds.
3. Input the code "1470852369"
4. Press * Button.
Then password will be changed to 1234
ZTE projector needs a factory reset how can I fix this problem
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap Apps > Settings > Backup & reset > Factory data reset > Reset phone.
  2. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  3. Tap Erase everything.
Master reset with hardware keys
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card. If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  3. Press the Volume down button to highlight wipe data/factory reset.
  4. Press the Power button to select.
  5. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  6. Press the Power button to select.
  7. Wait as the device resets.
Device resets ZTE ZMAX
How to master reset zte z798bl
Hi @Kyle Glenn
Please follow the steps below:
Hope this helps!
Reset zte maxx
  1. From any Home screen, tap the All apps icon.
  2. Tap Settings.
  3. Scroll to the 'PERSONAL' heading, then tap Backup & reset.
  4. Tap Factory data reset.
  5. Tap Reset phone.
  6. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  7. Tap Erase everything.
  3. Press the Power button to select.
  4. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  5. Press the Power button to select.
  6. Wait as the device resets.
I recently got a used ZTE 2958 and it wont advance past the google sign in screen due to a previous reset. No info known re former owner. Suggestions?
You need to do a factory reset.
If the device menus are frozen or unresponsive, you can master reset using hardware keys. To perform a master reset, follow these steps:
  1. Back up all data on the internal memory.
6helpful
2answers
Want to get a master code for reset my NOKIA E52phone.
Absolutly if you wanna Reset/Master Reset you Nokia Phone,
you can do it by :
1.Turn Off your device
2.
Press and Hold Call Button/Green Button + * + 3 + Power Button
3.Hold for 5 to 10 Second until you see Nokia Logo is Blinking
for once and then release all.
4.if you see the regional menu (like Country Selection,Language,etc)
that mean if your phone is Done to Master Reset.
I need the location of the master reset button on a hp probook 4510s
Hmmmm, what do you mean by the master reset button and what do you intend to accomplish by pushing such a button. If you're wanting to "reset" your operating system, then you will need to use your recovery partition if you have one, or the recovery discs if they came with your laptop. To my knowledge there isn't a master reset button on your laptop; other than the power button.
5helpful
2answers
Master rest code N70
THe master reset code, wont works with either the N series phone or the New phones..
Only way is reformatting the phone,will hel you to reset the security code..
To Format the phone
1)Switch off the phone
2)Hold 3,* and Green button simultaneously
3)Now press the power button holding the 3 button, After 5 seconds leave the 3 buttons
4)You phnoe should say, formatting and all your data would be reset to factory orginal
CAUTION: You will loose all the data and contacts stored in phone memory, But this is the only way
RNJ VINODKUMAR
3helpful
Sony str db870 master reset
If the power of the Receiver is ON, press Power to turn OFF the power. Then, hold down the MODE + button and press the Power button together.
S.F Intialize appears in the display and all sound fields are reset at once.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
