Gltf2940es3 front load frigidaire washer would wash but no final high-speed spin...checked error code and got E47...went on 1 week vacation...came back and washer will not work at all, not even in diagnostic mode...new error code is E6E...Main control board or motor(speed) control board? I've seen both opinions thus far and don't know which route to go. I did already replace the door latch thinking the original E47 was the root cause. Didn't help...still get E6E...
It's the main control board that needs replacing. Here is a link to the part.
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
SOURCE: frigidaire front load washer won't final spin
THERE ARE A COUPLE OF CONDITIONS THAT WILL PREVENT THIS UNIT FROM SPINNING :NOT COMPLETELY DRAIN AND FAULTY DOOR LOCK AS SY.
FIRST REMOVE ELBOW ADAPTER HOSE FROM TUB TO PUMP AND MAKE SURE IS COMPLETELY CLEAN ,HOSE STRAINER THEN CHECK IMPELLER @ DRAIN PUMP NOT TO BE BROOKED , DEFORMED .DIRTY OR LOOSE IF IS LIKE THIS REPLACE PUMP IF NOT PUT EVERYTHING BACK TOGETHER ,MAKING SURE THE STRAINER IS ALL WAY DOWN (IF IT HAS ONE) IF NOT IT WILL GET LOOSE AND DAMAGE YOUR OUTHER TUB ,THEN THIS IS IT .
THEN CHECK PRESSURE SW HOSE FOR LEAKS AND BLOW SLOWLY AND CAREFULLY TO CHECK PRESSURE SW .IF CHECKS OK THEN REPLACE DOOR SW ASSY AND RUN ONE IM VERY SURE THIS WILL TAKE CARE OF YOUR SITUATION ;NOW GET ON YOUR KNEES , GET DIRTY AND HAVE A GREAT DAY!
MAYITOJHONES
Replaced main control board and fixed the problem.
