IP CAM VIEW found in the Itunes Market: http://itunes.apple.com/us/app/ip-cam-view/id471794610?mt=8# should work as long as you have the network settings properly configured in both your DVR and Home Network. I recommend setting a Static IP for the DVR on your Home Router. After you have assigned the IP goto the network settings on your DVR and input the IP Address you assigned, the SubnetMask of your Home Router(usually 255.255.255.0 or 255.255.252.0), and the Gateway of yourHome Router.(i.e. 192.168.0.1/192.168.1.1/192.168.1.254). While you are on your Network screen I recommend changing your default TCP Port andHTTP Port to something that is not commonly allocated. As with most Routers you must Create a pinhole in the firewall to allow the outside traffic in. Select your DVR's IP on your Router and Create Definitions for both Ports that you set on your DVR's Network Menu. If your DVR and Router didn't reboot after saving these changes reboot.On the phone ap I found the following two cameras to work with the H.264 DVR System V2.00.R05:
For the Host/IP field, You use your Home Routers Internet IP. TCP port is the number you set on the network menu of your DVR. Ch.# is the Channel Cam (1-8, and 9 being a single feed of all 8 channels)user names and passwords are case sensitive.
I hope this helps
Thaks for the advice but no luck, can't figure out what's wrong , can view my cameras on any pc on the Internet just not on my iPhone got the IP CAM app don't know how to add the two cameras you suggest, I got static IP and did everything like u mention, maybe I'm missing something if you got any other suggestion please let me know
Thanks Rob
You may be lucky because the battery acid may not have gone beyond the contacts in the battery chamber: open battery chamber and clean out especially at the bottom of the chamber and blow out any loose stuff when you finished cleaning ( use pencil erazor or something similar , but do not use sand paper or anything that will damage chrome plating of the contacts ; you do not want corrosion at later stage ).
