I turn on my camera, and I get an error message stating Lens error, restart camera, the lens is open and will not retract, I have removed the battery and tried to restart. It will not go beyond the lens error message.
Try to unstick the lens by gently pushing it in or pulling it out a little bit. IF that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
I have the same problem, "Lens error, restart camera" . Lots of beeping & green light flashing.
I too have the same problem. have tried recharging battery and still contiues to come up with lens error restart camera. The lens will not retract either. Would just like to know if it can be fixed/ or worth fixing.
