Google Nexus S (16 GB) Smartphone Logo
Posted on Jul 06, 2012
My nexus s is slow. how can i speed it up? - Google Nexus S (16 GB) Smartphone
Nexus 7 slow and unresponsive
Do a factory reset. You will lose all data unless saved to SD card or Backes up to google. If that doesn't solve it then download 360 security from the play store and run it.
When I installed the update in January it made my tablet go so slow and took forever to turn on. Will the new update fix this?
It should be OK mine was. U mention its going slow ..if u have the full main app of Facebook uninstall it u can open Facebook in you're browser just write Facebook login in browser...I have 2 nexus 7 and the full Facebook app makes them go slow & lock up hope this helps. ...,.
1helpful
How do I speed up my nexus 7?
try the cleaner master from www.moborobo.com and remove the old apk and junk
How to speed up nexus 7
Try first: restart. If that does not help try hard reset:
press and hold Volume Up + Volume Down + Power until the device powers on. Some app might run in the background, so you might want systematically remove the apps going back in time, or simply do factory reset.
I have a Felt M-P bike. It has a Nexus 3 speed hub shifter. The screw that holds the outside housing in place on the end of the axle will not tighten down and the housing keeps popping off the axle. I...
If the bolt itself is stripped then it is most likely a metric thread. If your hardware store does not have them try an Ace or True Value - or a bike shop! Hopefully it is the bolt and not the part it threads into.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
1helpful
How to assemble the shimano nexus three speed cable to the nexus hub? Looks like you just push on and tighten the screw , seems to simple. Need someone else to advise me. thanks
Although i have not worked on a Nexus hub, Shimano's tech sheet page has your info. The Nexus drivetrain is found on the fourth category on the left (Comfort), and the hubs are 2/3 of the way down the page under "SG Internally Geared Hubs". i was not sure which one was yours (there are quite a few!), so i figured it best to just pass on the site to you.
Hope this helps,
matt
3helpful
I need a manual for a Shimano nexus 3-speed hub installation.
http://techdocs.shimano.com/techdocs/blevel.jsp?FOLDER%3C%3Efolder_id=2534374302052334&ASSORTMENT%3C%3East_id=1408474395181679&bmUID=1248577311531
scroll down to Nexus
Jul 25, 2009 • Cycling
Top Google Cell Phones Experts
ADMIN Eric
ADMIN Eric
nexrad_chris
NOEL
NOEL
Are you a Google Cell Phone Expert? Answer questions, earn points and help others
