Either the drive belt has an issue or the programmer has one, a technician will be able to tell you wich. If it is the programmer it is probably a task beft left to a professional.
When my white goods start to go wrong and hefty repair bills loom on the horizon I prefer to buy a new machine if the costs are likely to be high, i PREFER THE PEACE OF MIND
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine. At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
Take the toe kick off of the machine. Reach in and up to the right.
There is a "manual" which covers error codes and possible remedies but
not much more. Hope your "manual" is still there.
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
