Canon SmartBase MP390 All-In-One InkJet Printer Logo
A
Anonymous Posted on Jul 06, 2012
How to reset ink u051 mx366 - Canon SmartBase MP390 All-In-One InkJet Printer
2 Related Answers
Anonymous
  • 56 Answers
  • Posted on Mar 01, 2010
SOURCE: check ink U051 col
hi...you can try to press the reset button in five second.,.,
A
Anonymous
  • Posted on May 29, 2008
SOURCE: u051 error showing / Will not accept ink
when the message appears, hold the reset button for about 5 seconds, this disables ink monitor on most canon models
Code U051, change the cartridge color and it is the same.
The error U051 / U052 indicates that a communication issue with the print head. This can be caused either by the print head not being installed or print head not working properly. The issue U051/U052 canon printer can be fixed easily.
·Reset the print head
·Restart the printer
·Check ink cartridge
Read continue the steps to fix the U051/U052 error code in canon printer.
20helpful
4answers
Printer canon mx 366 saya. error 5B00. tidak bisa berpungsi ketika di hidupkan muncul error 5B00. sudah dilakukan reset manual tapi tak ada hasi. masuk ke menu tidak bisa. mhn petujuk untuk masalah ini....
I have best solution for reset error 5b00 Canon MX366 about waste ink absorber full :
1. Fisrt step : entering service mode, using this method (dont use other method!) press & hold "stop" button and than press "power" button, release "stop" button and still hold "power" button and than press "stop" button about 5 times ( 1, 2, 3 , 4, 5) and release "power" & "Stop" button.
2. Printer will be entering to Service Mode with indicators " Printer LCD to become full drak and CPU detecting new hardware (dont do anything).
3. Download Servicetool V 1074 for Canon IP2770, download and entering to this Sofware.
4. prepare paper on the printer and Clik "MAIN" on the Menu Servicetool V1074, if success canon MX366 printing "D=000.0
5. turn off Canon MX366 and remove power cord, wait about 60 second, reinsert power cord and turn on your printer,....... o la la la your printer was normal,..... ( ngono ae kok mumet)
6. if you have any qustion, send your email to : [email protected], thanks God bless U
2helpful
How to fix error code u051 cannon printer mp480 error code u051
Reset the Print Head:
Make sure that the power is turned on, and open the Paper Output Tray gently
Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support (A). (The print head will move to the replacement position.)
Remove all the Ink Tanks in the following manner.
Push the tab (B) and lift the ink tank to remove.
Do not touch the Print Head Lock Lever (C).
Raise the print head lock lever.
for other more help click https://cbrtechsolutions.net
1helpful
5helpful
Check ink U051 col
43helpful
3answers
Pixma mx328 check ink u051
The error usually came out after you refill ink on the black cartridge...there is no way you can make the printer work without resetting the ink cartridge..
Try to reset the printer using this procedure.. it will help.
1. turn off the printer..
2. press/hold the stop/reset button..and press/hold power button too..
3 while holding power button, release the stop/reset button..
4. then press the stop/reset button twice..
5. release power button..and wait until the power button lights a steady/still green and says "idle"...
6. open the cover...take out both catridges.. then turn off the printer.
7.put back the cover then turn on...
8. now put the catridges back.. and wait for some time to return to display menu... then try to print...
The printer may still prompt a "black ink volume unknown and color ink volume unknown" but don't worry that won't affect the operation of the printer. And you will able to use your printer, fax and scanner.
Do this every time you refill the ink of the cartridges.
If you find this solution helpful please vote on this on the YES below..thanks..
6helpful
2answers
My Canon Pixma MP220 is has an error code U051 Chk Ink Blk Col, but i have just refilled my ink cartridges
Same thing happened to my MP220. U051 chk Blk and Colour. I got my colour one replaced as there was an electrical fault in it. So the solution is to replace whichever one has the electrical fault or both and it works just fine. Refilling only works for a certain number of times. 4 or 5 at most and mine only lasted 1, so not always successful.
U051 error showing / Will not accept ink
old marine
old marine
ZJ Limited
ZJ Limited
