you will probably have to buy some 2 to 1 input plug adapters and set them up
i cant see your television so im not sure of its speaker set up
hope this will help you
Not sure how you're hooked up or what model TV you're using. If you mean the TV sound through RCA cables is the source and you're wondering why it's not surround. Well, it's not multichannel. Please fill in some details.
You need to program the TV remote to work the surround sound. You gotta select a button that says AV or Aux on the remote. Then you gotta input some #s so the TV remote can send the proper infrared beam to the surround receiver. The codes will be in the users manual to operate different brands of electronics.
The calibration mic thing is to balance the sound evenly on surround sound systems, it replacles the older systems "TEST TONE" speaker setup, in other words it will balance each speaker say in a 5.1 setup to adjust the level output so the listening position is not overwhemled by say the rear surround speaker overriding the front left & right speaker or the most critical the center speaker. The calibration mic uses computer tech to make it easier for the user, no sound pressure calibration is needed as with the test tone setup mentioned earlier. The wireless speaker situation could be possibly waiting for the calibration confirmation, Read any user manual information if available.
Hook your satelite receiver to your TV. Then run from your TV audio out to your surround sound system. This should make your surround sound system work with anything your TV is playing.
Press the surround button on the Philips remote to see if the subwoofer will begin producing noise - the surround button switches the mode from simple stereo to full surround. I would test the surround button while watching a DVD, because not every tv channel is going to even produce surround effects. Good luck!
are you trying to use the surround sound for movies or music ? , ive got the dvd version of this system (sc-dv290) and ive noticed the surround sound tends not to perform well with music , but sounds great with movies. i think its because the movies have dolby digital and music does not. The dolby pro logic in my opinion doesnt really make that much of a difference in sound unless the sound is cranked up past 44db on the amplifier. the only cables you need are the ones that are attached to the surround sound speakers and they cannot be removed so it cant be the wiring . I reckon you have a 1 - faulty system 2 - listening to music 3 - maybe not pressing the pro logic button on the sound processor. Hope this helps
im not sure if it matters what kind you buy if only some will work on a pc
