1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
scott jones Posted on Jul 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1995 V8 350 CI CHEVY 1500 WONT STAY RUNNING - 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Kardoc
Level 3:
Top Expert:
  • Chevrolet Master 7,503 Answers
  • Posted on Nov 25, 2018
Kardoc
Chevrolet Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2757193
Points
58323
Possible a very bad vacuum leak. Also could be bad fuel. there again maybe that your plugs are worn of your fuel filter is dirty. Could also be that your ect sensor is bad. A few of the things for you to look at.
1 Related Answer
Anonymous
  • Posted on Oct 14, 2009
SOURCE: My 91 chevy truck wont stay running it starts up then just dies
my 2001 silverado wont stay on. it starts up and runns for a while then starts to putt then it dies
2003 chevy silverado 4.3 starts but wont stay running
Correct fuel pressure? EGR stuck open? IAC dirty/stuck? Throttle blade hanging open preventing IAC from working? Yune up issues?
1997 Chevy Cheyenne won't stay started
Most likely a bad ignition switch (unless you just installed a security system) these have a history of ignition switch Failiures.
1997 chevy 1500 truck starts but wont stay running
ignition module
ignition switch
fuel filter
bad crank or cam sensor
Parked the truck and now it wont start,,new fuel pump/filter.will run for a min if sprayed with starting fluid but wont stay running yes has gas in it 1995 chevy s10 4 cyl
check change the fuel filter and check the vacumn to the fuel pressure regulator also check the fuel lines to make sure one isnt collapsed as well
1helpful
96 chevy truck wont stay running -- it starts then dies
Hi
Check the battery power of the vehicle. if battery hasnt have sufficient charge give it for charging .Also check the fuel and oil levels of the truck
Thank U
Please rate me as it wil cost u just one click
1helpful
2answers
1helpful
83 chevy truck starts then dies off. wont stay running
when it shuts off is it a warm engine condition going into closed loop , no check engine light ?
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
