Question about Car Audio & Video
I bought this 93 pontice firebird with no dash lights because they hooked up a cdplayer in it,an am trying to get them fixed what wires needs to be hooked back up?
    Problem Solver:
  • 14 Answers
Try looking for the yellow wire from the cd player. find the wire that they connected it 2 and take it off. if they cut it 2 connect it 2 the yellow wire find the cut off bit and join original wire together. probly have to check the fuses.if not yellow wire mite b red. probly yellow tho.gud luck
Posted on Dec 28, 2008
SOURCE:
It want crank by the key I cross the relay and starts but only runs for a few sec
Car Won't Start Because of Anti-Theft System That Uses ...
repairpal.com > Problems > Pontiac > Firebird
Car Won't Start and Security Light is On on Pontiac Firebird. Problems with the anti-theft systems using the raised-chip key can prevent the car from starting.
Security light was on and car won't start - CarGurus
www.cargurus.com > Questions > Pontiac > Firebird
CarGurusJul 24, 2007 - Check to see if your key chip isnt worn out(small silver thing on top part... My 1994 pontic firebird won't start and I no everything works great on ...
Pontiac Firebird Questions - security light - CarGurus
CarGurusFeb 5, 2009 - Hi I've recently bought a pontiac firebird the car doesn't have keys as previous owner ... Security light was on and car won't start 3 answers.
91 Pontiac Firebird won't start (Pontiac Firebird)
answers.edmunds.com > Edmunds Answers
Jun 18, 2008 - My '91 Pontiac Trans AM GTA will not start. When I turn the key, the engine does nothing, as if the battery were dead or the clutch pedal wasn't ...
Jan 09, 2016 | Pontiac Firebird Cars & Trucks
Where to hook up power wire for aftermarket driving lights in 93 Nissan Maxima
You should use a dash mounted switch and connect the power wire to a wire on the fuse block that goes off when the engine stops. That way the lights can assist you in all driving situations. Why limit them to only operate on low beams?
Oct 31, 2017 | Nissan Maxima Cars & Trucks
Need to install a cdplayer in 70 chevy truck?
Because of the year of the truck you will not have any wires pre-wired in the truck, go to a Radio Shack, car audio store or Best buy and buy yourself some speaker wire for vehicles, about 5 ft of 14 - 16 gauge yellow wire, 5 ft of 14 - 16 gauge red wire a couple of 10 amp fuses and 5ft of 4 gauge black wire.
You are going to run the Yellow, Red, Black wires together from the radio space where the radio sits in down to your steering column, the speaker wires will go to your speakers from the radio, a + and a - lead to your speakers and connect them as needed.
Now back under your dash you will connect the yellow wire from the radio to the 12 volt + wire under your steering columns 12 volt power wire with a fuse inline, if you hook up a test light to this wire it will light up the test light without the car switch being turned on, the red wire will hook up to your ignition switch wire and your balck wire to the vehicles ground chassis, basically ground that wire to a non painted surface of the vehicle. This radio needs to be hardwired like I explained.
Good luck and hope it helps.
Lex.
May 21, 2010 | Car Audio & Video
1987 pontiac firebird, does anyone know how to fix dash lights.?
you have to take out the gauges, they will be on the back. In some cases you have to take apart most of the dash to get the instrument panel out, sometimes you can just take the trim off the instrument panel. I had to take apart most of my dash in my 86.
Oct 04, 2009 | 1987 Pontiac Firebird
My 1980 TA has no dash lights
check all your fuse links(if you haven't allready),then check to see if your aftermarket stereo and amp is hooked up properly.hope this helps
Jul 22, 2009 | 1979 Pontiac Firebird
Putin in a cdplayer
go to a local walmart or advance auto store you can get the dash kit along with the harness to plug into you factory plug the wires from that should color code match any aftermarket radio
Oct 25, 2008 | 1993 Chevrolet C1500
1989 Pontiac Firebird, 5 spped, v6 2.8L
check if you have a drain plug in your fuel tank, if none, then there is no easy way but to bring down the whole tank and remove the old fuel. be careful in handling fuel.
tnx 4 using fixya,
drcool
Oct 14, 2008 | 1989 Pontiac Firebird
Need dash wiring diagram for a 1993 Dodge Colt
i had this problem , all you need to do is hook the ground wire from your new radio to the braided wire that hooked on your old radio and insert a bolt in the hole and tightin ,then check fuses and your dash lights will work and dome light.
Oct 05, 2008 | 1993 Dodge Colt
Car Audio & Video Logo
71 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
