Question about Video Game Consoles & Games
Iron man exe. error( file not found )
When i start the application it say file not found please help
    New Friend:
  • 4 Answers
Try running it in compatibility mode windows xp
Posted on Jul 03, 2013
I have downloaded iron man the game but its files are missing
Posted on Jun 16, 2013
3 Suggested Answers
SOURCE:
SOURCE: Upgrade for settlers downloads but won't run
I had this issue as well. Download the patch directly from the website, and run it locally. Afterwards the updater won't find a newer patch, and goes directly to the game. I don't know whether this will break again once a new patch is released, but you should be able to manually install it again at that time. Patches can be found at http://www.ubi.com/US/default.aspx under support --> patches.
This link may take you directly to the right place.
http://www.ubi.com/US/Games/Info.aspx?pId=5923&tab=download&dcId=63
Posted on Jan 01, 2010
  • 19 Answers
SOURCE: i get the following error
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then would remove them and see if the error goes away. If it does then send the memory back and get a refund!
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention.
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
This error also seen when people have updated drivers for their graphics card. If this happens just roll back your drivers. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
Posted on Mar 03, 2011
At start up application error message is displayed saying that the application explorer.exe has encountered an errorand must shut down. help?
press F8 on bootup and start it in safe mode with network, if that doesn't work its a restore, unless you know a man who can copy the offending corrupt file and replace it, but safe mode might just sort it. you never stated what operating system you are using but try it anyway.
Feb 01, 2011 | Sylvania G-Netbook
Ryukcqf.exe application error problem continuesly occured in my laptop please help me
Ryukcqf.exe appears to be a component of a virus. housecall.trendmicro.com for an on-line virus scan
Jun 14, 2009 | Dell Inspiron 1501 Notebook
Rundll32.exe not found
Insert your installation CD into the drive. Reboot and select the repair option. This should reinstall any missing files without losing any data on your hard drive. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 16, 2009 | Computers & Internet
AegisE5.dll was not found.
hi,
http://www.fix-all-dll-errors.com/aegise5.dll/
u can go to this site...
as I registered few dll's from this site...worked in my case :)
Jan 03, 2009 | Televison & Video
Error in application download due to regsvr.exe is missing
Window is asking about Regsvr.exe file at the start up.
Dec 26, 2008 | Microsoft Windows XP Professional
The file bcmwltry.exe is the tray bar process for the Broadcom Corporation Wireless Network software.
You can try eliminating the program from start up.
Click on Start >>Run, type "msconfig" (without the quotes), then click on OK.
When the System Configuration Utility loads, click on the "Start Up" tab, then scroll down to the "bcmwlt.exe" entry and UNCHECK the box next to it.
Click on Apply, then OK, and the computer will need to be restarted. Do it. Upon restart, you'll see a System Configuration Utility warning. Simply choose the option to stop it from repeatedly opening.
This will be fixing your problem
Have a great day!
Pablo :-)
Oct 22, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Error messages please help
after the booting type msconfig then go to start up and uncheck irappl.exe reboot your laptop
Sep 30, 2008 | Computers & Internet
O2 xda 2 mini application installation
There can be three types of applications that you download from freeware sites:
  1. '.cab' files, that can be directly installed from your PPC
  2. '.exe' files, which are direct to be run applications that need no installation, just have to be placed in any folder and a shortcut has to be placed in the start-menu.
  3. '.exe' setup files. These files have to be opened in your PC while having your PPC connected thru Active Sync. This will install the application to your PPC thru your PC. These should be the kind of applications that you might be talking about for which you get such an error message "Not a valid PPC application!"
I think this should have solved your queries regarding PPC applications.
If this really solves your problem, Please Rate...
Aug 09, 2008 | Bosch WFMC 2100 Front Load Washer
Video Game Consoles & Games Logo
4,457 people viewed this question
Top Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
