Question about Toro Lawnmower 20099 Mower Mowers Lawn
Replace blade on Mountfield/Honda GCV135 mower
Cannot undo nut. Right or left hand thread?
2 Suggested Answers
SOURCE:
  • 111 Answers
SOURCE: how do i replace blade on mountfield princess lawn
It should be a standard thread. You may need to put a shop rag into the spark plug hole to make sure the engine does not turn while you are trying to remove the blade.
Posted on Mar 30, 2011
Testimonial: "Thank you for your help it was much appreciated, did the job of replacing the blade with no trouble thanks again."
What direction to turn nut to remove blade from an HU625AWD LAWN MOWER
normal right hand thread so counter clockwise to undo
Apr 30, 2017 | Garden
What would cause my walker zero turn mower right blade to fall off of become loose after tightening the nut about every 5 minutes while mowing?
check to see if that side is supposed to have a left hand nut on the correct spindle
are you using the dish shaped washer under the nut
are you using a spring washer or nyloc nut
Mar 28, 2016 | Garden
Cannot remove mower blade pulley nut
I think its a left hand thread, you undo it clockwise (the "wrong" way)
Nov 08, 2013 | John Deere 22HP VTwin 48" Riding Mower
How do i replace the blade holder adapter on Honda Mower?
19mm or 22mm. Right handed thread. Screw on like normal nut to remove.
Aug 22, 2012 | Honda Garden
How do i replace blade on mountfield princess lawn mower. is it a left or righhand thread
Mar 28, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Replace blades on Mtd mower deck
no they are not left hand threads if nuts have molded washers you must use an impact gun. wash holds too much of blade surface and will not turn against it
Jul 17, 2010 | Yard Machines 155 Torque Briggs Stratton...
I have a mountfield rotary mower,and i need a new blade but i cannot undoe the existing one.
are you loosening it the right way?as some have left handed threads and loosen the opposite of a normal right hand thread,otherwise take it to a garage and have them remove it with an impact wrench
Apr 30, 2010 | Garden
Are the nuts holding on the blades reverse threaded?
If a blade, when viewed from above, rotates clockwise, it will have right-handed threads. This is because the shaft is turning to the right, and the resistance imparted on the blade will tend to tighten a right-handed fastener. If a blade rotates counter-clockwise it will have a left-handed fastener. I don't know this mower, but this is a universal thing.
Apr 23, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Toro Lawnmower 20099 Mower Mowers Lawn Logo
94 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
roeb
Are you a Toro Garden Expert? Answer questions, earn points and help others
