Dishwashers Logo
jim koudys Posted on Jul 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door spring rope broke on door , door falls when opened like to fix it need part and diagram of unit
Door falling down rope spring broken need part and schematics so i can replace
Anonymous
Level 2:
  • Expert 375 Answers
  • Posted on Jul 06, 2012
Anonymous
Expert
Level 2:
Answers
375
Questions
0
Helped
141820
Points
888
Http://www.bosch-eshop.com - enter the correct model number: SHE43P05UC in the search box on the right side, select which dishwasher you have from the results list. Click on the number of the part you need, it should show the manuf. par number on bottom.
or go to http://www.searspartsdirect.com and check there.
Once you get the manufacturer's part numbers - go to http://www.repairclinic.com - they have pictures of most parts.
Vlad,
First Choice Appliance, Sacramento
5 Related Answers
Jeff Meyer
  • 423 Answers
  • Posted on May 06, 2009
SOURCE: Door falls open
Without knowing the make and model of the dishwasher, it is hard to provide specifics. It is very rare for the hinge/spring to be repairable.
Generally, the hinge and spring assembly needs to be replaced as a single assembly. If you replace one, know that the other may fail soon, so consider replacing both.
Good Luck
Anonymous
  • 457 Answers
  • Posted on Feb 26, 2010
SOURCE: The door spring is broken and the door falls open
there is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
Anonymous
  • 43501 Answers
  • Posted on Jul 23, 2010
SOURCE: door falls open
here should be your parts...
http://www.repairclinic.com/Appliance-Parts?s=t-KUDI01FLSS-%3d%3d
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Anonymous
  • 43501 Answers
  • Posted on Aug 11, 2011
SOURCE: LG LDF6810st dishwasher door spring seems to be
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Anonymous
  • 15 Answers
  • Posted on Nov 24, 2011
SOURCE: no spring in door
Hi there Mathew, yep your diagnosis sound correct to me the LG dish washers have a string with a plastic lug that conects them to the springs. The plastic lugs and known to brake off the part number for the replacement strings is 4933ED3002A you will need two of these one per side. I hope you find this usefull please contact me if you need any further asistance. Regards Gary.
Kenmore elite 13862 door falls open horizontal, won't stay up part open.
There are two spring units, one on each side of the door near the base, they use a small cable or rope on them, check to see if one or both is broken. You have to pull the whole unit out of the counter space to check it.
2answers
Why does my dishwasher door fall freely when opened?
There are springs and pulleys that assist the door. They use a nylon rope that is very thin to connect the pulleys door and springs. The rope is most likely broken.
Jan 10, 2016 • Dishwashers
1helpful
My garage door will not open. I pulled on the emergency rope to see if that would help but it did not.
Your torsion spring is probably broken. After you pull on the emergency rope, press the remote, that should move the chain and emergency lock out of the way, then you and 1 or 2 other people may be able to lift the door up if you really need to get the vehicle out. It depends if it is a single or double door or wood or metal, how heavy it will be. This can be dangerous and it could fall down on you. Check your torsion spring above the top of the door when closed, if there are two pieces then it is broken (on a single door.) A double door will have two springs, one on each side. One may be broken. You will need to get all the springs replaced, it counterbalances the door. If you have a garage door with arms on it, then the compression/extension spring is probably broken. If you are mechanically inclined, you can replace them, it is dangerous, be sure to watch a UTUBE video on it.
The door to my dishwasher opens too easy now. Like it falls down too fast. what can I do to fix it?
A spring or a rope broke that holds the door...they are on the sides of the door to help support it..
That is not that hard to fix and you can easily buy the parts yourself online...
heatman101
May 12, 2011 • Dishwashers
Something has happened to the door of my dishwasher when you open it it falls down heavily and now when I put the dishwasher on the door keeps opening
The door springs or ropes have broken...
heatman101
Mar 16, 2011 • Dishwashers
5helpful
A spring or something has broken in the door of my kitchenaid dishwasher. Now the door is extremely heavy and falls to the ground upon opening. How can I fix this problem? Thank you!
Hello, Welcome to FixYa.
While I don`t have diagram or illustration I can give some insight because this is actually very common.
It is a fairly minor procedure to replace it/them. Slide the entire unit out from the cabinet a couple or three inches and you`ll see the plastic roller assembly and rope ( except yours is likey broke...at least one by the sounds of your description ) attached to the side.
**You`ll need to insure your connections will allow you to pull the unit out however, otherwise they - water, power, drain hose - must be disconnected to prevent any damage.**
If you have any reservation to performing this repair on your own please call in a qualified appliance technician.
The parts ( # 1059756 @ repairclinic ) come in a kit as I alluded to and will look like what I attached below...
These are available at most brick & mortar appliance part locations or on-line vendors such as "repairclinic.com" "searspartsdirect.com" or "apwagner.com" to name a few.
They range in price for around $20, or you can just purchase the rope/link seperately for about $4 part # 1159210 @ repairclinic.
I recommend replacing the entire kit and checking the spring itself, if it looks ok and not stretched or broke it is likely ok...they are seperate from the kit ( # 830967 door spring @ repairclinic as well )
Hope that helps move you forward. Thank you for visiting "fixya" today.
Please take a moment and rate the solution provided here or a testimonial if you feel warranted.
Let me know if you require further assistance and good luck.
macmarkus :)
2helpful
2answers
Door falls open
The side spring springs could have unhooked. Some springs connect to a nylon rope that slides over a plastic guide. The rope could also have snaped or slipped off the guide. You need to open the sides (normaly the back first) to check. This is easy to fix if you have the right tools...
The door to the dishwasher is very hard to close. The door also falls down to the floor which makes the carriage/basket fall down as well.
sounds like one or both of your door links are broken check your hinges. you should ahave a large spring and a piece of rope that attaches to the door. let me know if this helps you
2helpful
Door falls clear to bottom when opened almost got foot broken it was repaired by sears 2 years ago now broke again Elite mod=665 16982201 ser=fp2401121
one of the nylon rope which connects the door hinge to the door spring is broken.usually with time the rope wears out and break.it is preety easy fix. u have to pull the unit about half way out and look for ropes on lhs and rhs bottom of the unit.buy the rope kit(it comes with 2 ropes and plastic roller unit.). just see the one which is not broken and accordingly install the broken one.usually u dont have to install the new rolers unless they are broken.
Aug 26, 2009 • Dishwashers
4helpful
Door drops -- no spring action
there are two nylon ropes that hook the door hinges to the door springs on the left and right side of the dishwasher.usually with time of rope breaks and the door stars to fall down.to fix this pull the unit out and look for the broken rope on both sides of unit at the botom.the new ropes comes in a kit and are abt $15.00.it contains two ropes and new wheel assly.u dont realyy have 2 chge wheels unless they are broken.but chg both ropes.to get rid of that squeeky noise aplly some bearing grease on the rollers over which the rope slides.that will take care of it.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
