The "brass input shaft" is designed to break in the
event of too much torque being applied; it acts as a shear pin. For safety considerations, I would be careful what I used to replace the shear bolt/shaft. Failure of the shear bolt is
necessary to prevent more serious damage to either: 1) the mixer, 2) the
pasta attachment, and perhaps most importantly 3) the object stuck in
the pasta attachment (think of ingested clothing, hair, fingers, etc).
Unfortunately, KitchenAid refuses to supply replacement shear bolts (and
I couldn't get an answer as to why); however, they seem pretty good
about replacing the attachment under warranty. But logic dictates that a
part, such as a shear pin, that is designed to fail, will have a high
probability of breaking long after the warranty period has expired. To
that end, I have machined a bunch of spare shear bolts to the same
physical dimensions as the original part out of 5/16" brass hex stock. I
would consider making some available to others in need at a nominal
fee.
Have you tried going to the manufacturer's website? I have this pasta maker on my website and you might try one of the links. But you will probably have to get a new machine. You could also go to your hardware store. They might have a clamp that you could use. Good luck.
