Question about Konica Minolta bizhub C250 All-In-One Laser Printer
I have a Konica minolta c200 installed on my server, it will not print it sits and errors every print, i have re installed the driver and also i have stoped and re startes the printer spool. any other sugestions? Thanks, Stew
  • Anonymous May 11, 2010
    Specifically, what is the error?
Change your port to LPR and see if this works. Old Konica copier could not communicate with RAW ports.
Posted on Dec 11, 2008
6ya staff
SOURCE:
Abort code
contact service use go to www.konicaminolta.com
Oct 06, 2012 | Genuine Konica Minolta Konica Minolta...
USB print server fo Konica Minolta
try those print servers which supports GDI printing...
May 28, 2010 | Konica (950036) Print Server
Konica Minolta 350 is setup on server as a shared printer. Users have problem printing. The job shows in the que, but shows error printing. Please advise.
You should delete the present driver and reinstall the printer driver with the latest driver downloaded from their website. This will cure 80% of most problems like this. Last you will need to insure that the print settings are set up for network sharing.
Mar 15, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Unable to print from after attching to dlink printer server
check the paper type in the driver, it might be setted to Letter and you are trying to print as A4 or A4 to letter.
Jun 09, 2009 | Konica Minolta bizhub 180 All-In-One...
Unable to use printer over network with Server 2003 64Bit
Probably the best and easiest solution for your problem would be to buy an EDIMAX USB-Ethernet print server, or something equivalent. I have several of these running on the network at work. They're easy to setup and they work great.
Nov 11, 2007 | Konica Minolta magicolor 2430 DL Laser...
Zonet ZPS1001 can't detect Konica Minolta Magicolor 2400W
Persever. Change your usb points, and at the last resort get the cord from your old printer and use this type of connection. Go slowly thorugh the disc step by step and make sure you delete any previous installations of the print file in the control panel.
Oct 28, 2007 | Zonet 1-Port USB 2.0 10/100 Mbps Print...
Printing from 2 different pc, drivers installed on the server, get different quality
I think that quality settings is different for each user. If your printer have network card, pleas install printer with TCP/IP port in every PC, not from server, more job, but less problems.
Sep 15, 2006 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
234 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
