When i try and open Youcam this message apears "The application has failed to start because its side by side configuration is incorrect. Please see the application event log or use the command line sxstrace.exe tool for more details. Note that youcam was working fine for me before i did a system restore.
SOURCE: hi, im using window vista and my package and my
Have you tried plugging in the webcam to a different USB port on your computer? If not,then try it on
all the available USB ports and check if it works.
SOURCE: hi..i have a problem my cyberlink youcam..i can
Download a network camera software to make possible recognising a connection on the computer. if any damages are on the device would not function. The device could require driver updates.
SOURCE: Hello. My name is Florina
I don't think its your webcam that is at fault. I think it's already in skype. I have the same Lenovo model and there are times skype doesn't transmit video. So, I usually do is turn on and turn off the skype video call for the video to reappear. Can you do the following:
1) Make sure you have adequate lighting. Sometimes if you are in a dark room, skype will also transmit black videos to the other end.
2) Have you checked the video settings in skype? Go to Tools->Options. Click video settings. Click webcam settings and try to tweak your video from there.
SOURCE: My youcam wont come on it tells me it does not
Make sure you have the correct drivers installed on your computer. A webcam wont run if the computer does not recognize it.
