Some times hear cracking sound.
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
SOURCE: dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
SOURCE: TV Has Sound but no picture
Change or move yellow one, of the cables, or component. if not then something you need from expert..
SOURCE: Polaroid TDX-02610B, Tv was working fine, turned
If it is only the screen going black but the TV remains on and you can hear audio, then there is a problem with the backlight. It could be due to bad capacitors or it could be a faulty inverter. It requires repair by a competent engineer.
