HI TOM.WELL IF IT WORKED FINE FIRST THEN I SUGEST U DEFROST ALL FOR 24/48 HOURS OR REMOVE FREEZER REAR PANEL AND DEFROST ALL MANUALLY.IF U TAKE PANEL OFF THEN U MIGHT AS WELL CHECK HEATER,T/STAT.AH BEFORE THAT TRY TURNING DEFROST TIMER MANUALY.UNTIL IT CLICKSTOPS.WAIT 1/2 HOUR.SHOULD RESTART AUTOMATICALY.IF NOT THEN THATS YOUR PROBLEM.(LEVE ON OFF POINT FOR AN HOUR OR SO TO DEFROST ALL THE ICE THEN CLICK ON MANUALY AND REPLACE.GOOD LUCK.ALI
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
SOURCE: Maytag S/S model # MSD2756GEB
di you see or hear the fan running fan might be stuck check that out no fan no circulating cold air you may have problem with the heating element what make frost free inside you should melt all the ice inside around the damper check if you see broken glass the little heating element if it not broken and listen for that important fan if it running check it uot thank for using fixya pierre
SOURCE: 5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
SOURCE: Top refrigerator not cooling--freezer icy
This has happened in my GE side-by-side (model GSS20IEMDWW). For me,
the problem was caused by a faulty temp sensor in the fresh food side.
That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since
the compressor was running constantly, the evaporator coils (back wall
of the freezer compartment) eventually iced over (took about a week).
Since the fan that draws air over the evaporator coils could no longer
move any air (due to the icing), the temperature in the fresh food side
continued to climb. (The fresh food side is chilled through a hole with
a motorized door at the top of the dividing wall, so if no air is
moving in the freezer compartment, temps in the fresh food compartment
climb.)
I replaced the temp sensor in the fresh food side and
solved the problem for a while. About six months later I had the same
problem again, so I replaced both temp sensors in the freezer
compartment - which solved the problem again. (My fridge is about seven years old.)
If
you are going to replace any of the temp sensors, replace them all
under the principle of "if one failed, the rest will soon fail too".
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
