Whirlpool washing machine front loading,bearing problem ref AWOE 1012
Check this link for spares and tips to replace: bearing replacement
SOURCE: It is an awoe 8558. the spanner symbol is flahing
Hi, I have exactly the same problem. Did you ever get a solution to get the door open manually?
SOURCE: My Whirlpool AWOE 8748 washing
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: Whirlpool AWOE 9559B 1200rpm 6th
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
SOURCE: I need to replace the
Hi, Thank you for contacting
fixya.com. You can easily install a
new seal on your front load washing machine yourself. The seal is held on with
sealant with a type of glue that ensures the seal is tight. Also some makes and
models do not use sealant glue; they use metal or rubber bands to hold the seal
in place. Please check this link
for detailed step by step information as per your query:- http://www.appliance-repair-it.com/GE-front-loader-washer.html Please get back to us if
you have further query else please accept the suggestion.
http://www.ehow.com/how_5588402_repair-gasket-front-load-washer.html
seting
proplem
Problems & Solutions for
whirlpool awoe 1012
