Question about Netopia 3347 02 ADSL2 Wireless Router
Need set up instructions for 3347 02 1006 router
Router was a freebee from where my wife works. They were not using these anymore and were going to trash. Have AT&T DSL and want to install the Netopia but afraid might lose "everything" trying. Looked at AT&T help site and start getting worried about the password. Been so long since I did that that I've forgotten the password.
SOURCE:
SOURCE: Unlock netopia 2247 router
Well Netopia from eircom will sit on default username & password provided by eircom.
Only way you can use it with other provider is that you will need to update it with a new firmware from netopia's website !
Posted on May 29, 2008
ayamaya
  • 143 Answers
SOURCE: netopia router to strict
you need to open ports on your router so that it will give you proper connection to your ps3. you also need to set static ip address on your ps3.
here are the steps...
- go to a working computer that is wired to the router and open command prompt (for windows, click on start, then run, then type cmd or command, whichever will work, or click here if you are using mac)
- then you will be prompted with a black screen, on the blinking cursor type ipconfig/all
- take note of the subnet mask, default gateway, dns1 and dns2
- now go to your ps3 to set static ip adddress
* go to network settings and click network settings
* go to wireless or wired (whichever connection you are using for your ps3)
* then custom
* enter security settings
* now for your ip info click manual
* where it says ip address enter a static ip address (by default the ip address of your router is 192.168.1.254 so you can use any ip address that is on the same segment and was not being used by your other devices like 192.168.1.5 or 192.168.1.10
* subnet mask is normally 255.255.255.0
* put your default gateway number (the one that you have seen and listed from the command prompt) on the default router field
* enter the dns1 and dns2 also
* click next
* don't enable proxy server
* you can enable upnp if you can also enable it in your router
- now go bak to the computer and open a web browser, on the address bar of your web browser type the default gateway number (usually it's 192.168.1.254)
- you will be prompted with the netopia page, click expert modem on the left hand column, click yes, enter expert mode
- double click the word configure, go down and click on NAT, click static NAT, click the dropdown icon, see if your ip address (static ip address of your ps3) is there, if so click it, click on done, if this works, ignore the paragraph in brackets. (note: if it's asking for the default router ip address, you need to select/enter the default gateway number)
- click define custom service, click o port forwarding, select next , type anything in the service name, something that you will know its related to the ps3
- for global port range, if it's only one port that's being entered, enter the same port in the left and right hand boxes, in every case , enter the lower port in the box below saying base port even if there's only one port, and chage the TCP/UDP settings according to every port.
* here are the ports (note: repeat the same process for each one, after that window, select the static ip address you made in the drop-down list so it gets forwarded only for the ps3)
TCP port 80
TCP port 443
TCP port 5223
UDP port 3478-3479
UDP port 3658-3659
- when your done, click NAT on the left hand side, click the dropdown menu that has age of empires written on it and scroll to the bottom, click on the ports you made with the asterix beside them (*) and click enable , then enter the ps3 ip address in the bar , to enable them just for the ps3
- now click configure on the left and then click connection and tick the box that says upnp (note: you should have, when you click NAT on the left hand column, a static NAT address, enabled, it should be the same ip that you have used on your ps3, 7 ps3 ports, all enabled to the host device of your ps3's ip
- now , enter basic mode, click firewall, and set to low, this isn't dangerous as long as you have a desktop firewall such as windows or mcafee etc...
- save changes, and restart your router
hope this'll help you
ciao!
Posted on Aug 27, 2008
cnavarro
  • 2460 Answers
SOURCE: Programming Netopia 3347 wireless router
You mean what program? Telnet. Here's the quick setup. If it's already been installed and password protected, you'll need to grab the installation guide somewhere else.
http://www.netopia.com/support/hardware/manuals/3347W-ENT_qsg.pdf
Carl
Posted on Aug 29, 2008
SOURCE: Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
Posted on May 07, 2009
spincycleus
  • 62 Answers
SOURCE: netopia router test page keeps poping up while i'm on line
Reset your netopia by holding the reset button in for at least 30 seconds.
Reconfig your netopia again.
You do this by opening internet explorer. It will say "Page cannnot be displayed"
type 192 168.1 254 in the address bar (where you normally type www)
the username is admin
the password is the serial number on the bottom of the netopia
click on configure
click on quickstart
put in your userID like spincycleus@sbcglobal.net
and your password
click submit at the bottom
and then click the yellow triangle dealie at the top right
click save and restart the database
when it comes back on in a few minutes, you'll be online
If this doesnt resove the issue, then your firmware is messed up and its time to swap out the netopia.
spin
Posted on Jun 22, 2009
I cannot find information on my router to change my password. My password doesn't work anymore
You'll want to reset your router using the following instructions:
To reset the router using the reset button, use these steps:
  1. Look for the red reset button at the back of the router.
  2. Press and hold the reset button for approximately 5 seconds.
This will reset your router to factory defaults meaning you'll have to set up your router to the way you like it (i.e. adding a password to your wireless network etc.)
Jul 24, 2011 | Linksys WRT160N Wireless Router
My password doesnt work anymore
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Nov 13, 2010 | Belkin (F5D5231-4) Router
I have the internet plugged into my wireless g router and the internet light on the front lights up but in status screen when i connect to thr router via 168.***** it shows no connection and i cant conect...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Oct 06, 2010 | Linksys Wireless-G WRT54G Router
Why my wifi doesnt work anymore, it was working yesterday with dir 615
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Oct 04, 2010 | D-Link DIR-615 Wireless Router
I recdntly bought a new Dell desktop with windows 7. My Dell laptop worked for a few hours and the suddenly would not pick up the internet anymore. I have a linksys wireless-g broadband router which has...
Apr 29, 2010 | Linksys Wireless-G Broadband Router
Have an att 2700he-b wireless router. don't have dsl anymore. have cable internet & using cable ethernet output to use the 2700 as a router - works oOK for ethernet routing but need to set up the...
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online
through the modem.
modem
Then you need to connect the computer to the router
ad the modem to the router.
Jan 10, 2010 | 2wire Computers & Internet
CONNECTED BUT UNABLE TO USE INTERNET
You need to go into the admin area on the router and setup the internet connection. If your using DSL like at&t then you'll need to use a username and password using ppoe.
Nov 30, 2009 | NetGear WGR614 Wireless Router
Http://192.168.1.1 is not working anymore? i cant set up the router
Try resetting the router, press the reset button at the back for 10 seconds, after that release the reset button and then unplug the power of the router, then wait for 10 seconds and then turn it back on.
After that try accessing the IP of the router 192.168.1.1 (if this did not work try 192.168.0.1,this varies on the model number of the router). Or follow the same steps you have done previously.
Aug 15, 2008 | Belkin (F5D5231-4) Router
Internet connection to two devices
julianlee
can you tell me what type of router you are working with.
most routers have about 4 cat five cable slots where you can plug them into other computers. If you have a wireless router and you have a wireless adapter for the xbox that will work also.
another question are you working with the xbox360 and if so do you have an xbox live account?
another thing you might have to go into the setting of the router usally on the main computer to do this you will have to bring up the command prompt where it can be found at for windows 98/2000/xp/vista <start >all progams >accesses command prompt > type in ipconfig it will pop up with a default gateway and your ip you take the default gateway open your brosswer type it in. If you have not set up a password most routers have it as admin. from there i would need to know what kind of router you have ! hope that helps a little
let me know
djkb
Jun 21, 2008 | Computers & Internet
Trying to configure zyxel nbg334w router
If the router will not connect to the internet, you will need to create the PPPOE internet connection with the username and password that your ISP provided. BPCS
Dec 28, 2007 | Zyxel Prestige 334 Router
Netopia 3347 02 ADSL2 Wireless Router Logo
46 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
