Hello my son set the password on my Hisense 32' tv.. but he forgot it... so now all my tv inputs are locked, i allready tried to ''reset default'' in the setup menu, it reset everything exept the password... is there a way to reset the password? thanx
Thanks Tj the 0532 code works very well no matter the password
Thanks the 0532 works magic
My son set the parental lock which is a 4 digit code on my Hisense 55" 4K, Smart TV. (Great TV for the $$ Btw!) I spoke with a Tech rep from Hisense and he gave me a code that resets the "parental lock" no matter the password by simply entering 0532 then "enter" with the remote. This should reset the parental password and allow your TV to operate as it normall would.
I couldn't find it anywhere in the service manual but you can try calling there support line. default is 0000 if that helps anyPhone: 1-678-318-9074
Fax: 1-678-318-9079
Good Day
May I also get help my tv external buttons are locked... how can I unlock it
I forget my TV password can you help me recover it
Thanks Guys for the help,it works like magic,but my TV keeps locking without my permission,I don't know what's the matter
SOURCE: OSD locked Hisense PHD-4220
press menu, when osd locked appears press number 9 before osd locked disappears
SOURCE: My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON
2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
SOURCE: Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
SOURCE: Describe your hisense tv ~20in(?) Flat Panel TV. I
I HAD THAT SAME PROBLEM ALL YOU DO IS HOLD THE MENU BUTTON UNPLUG THE TV AND PLUG IT BACK WHILE STILL HOLDING THE MENU BUTTON GO TO GENERAL SETTINGS AND TURN ON RESET MENU ON FROM THIER AUTO SEARCH YOUR CHANELS NOW U CAN HEAR THE TV BUT BLACK SCREEN NOW UNPLUG YOUR TV FOR A FEW MINUTES PLUG IT IN AND YOUR TV SHOULD BE BACK ON THIS IS THE 3RD TIME IT HAS HAPPEND TO ME IT WORKS
i forgot my screen lock
why do I have to logon all the time to watch you tube ( I need to logon in once and must be set ) what do I do
It works out very well.. 0532
Thank you
Please l have 75”of Hisense and l can remember my password please
https://www.youtube.com/watch?v=zw73zkHJ...
